F4i problem HELP!
F4i problem HELP!
Here the problem...I dropped it 2 weeks ago (not hard) and it will not start.
for those that don't know I ride a street fighter, there is no tip over sensor.
it was by passed a long time ago.
when you turn the key on the only thing that happens is the fan and lights come on, no fuel pump or starter.
I have changed the wiring harness twice and nothing. I have changed out the starter relay, cpu and still nothing.
everyone says keep checking wires and I do and still nothing.
I have alway worked on my own bike but now I need help.
so please someone come up with some ideas.
Thanks
Thanks
Re: F4i problem HELP!
Swap out the ignition
hmm... the ignition usually causes funky things like that to happen...
if it aint the ignition it sounds like you got a bad computer
peyton aint seen a dash in years
I accually hooked up the cluster and it all seems fine when you turn it on??
I changed computors and it does the same thing
I've never seen this kinda problem before but it's driving me fu(kin nuts
Originally Posted by 955iDisastar
theres an extra wire on you kill switch as well, think its like p[ink or sumpthin, check the kill switch area. if disconected you **** wont spark.
well you had to put those wire togethr sumhow, did you check them? if the relay isn't turning on (but has 12v on at least one lead) your problem has to be in the switch areas. interlock or 12v.
they are still hooked together but I havn't checked if they are still getting voltage.
I'll have to try that when I get home from work
Originally Posted by Ed LegionST
did you check the fuel pump. try another tank on your bike. if its not that then its in you wiring somewhere you have a problem
Yup, I tried that
