Body Work Help
Old Nov 1, 2005 | 10:29 AM
neo4200's Avatar
neo4200 is an unknown quantity at this point
Body Work Help
I have a yellow and black 929... and I cannot stand the stickers... the white on the tail, and the yellow strips. Now, I took a hair dryer and used that to warm it up and the sticker came off like nothing, but I have some residue left on the paint...
Does anyone have any idea what kind of compound to use that will not screw up the paint???
Thanks for the help!
Old Nov 1, 2005 | 10:31 AM
Kyle_PBZ's Avatar
2 WHEELS UP!
Kyle_PBZ is a decent person
Re: Body Work Help
Goo Gone works. Also, fast dry enamel reducer.
Old Nov 1, 2005 | 10:46 AM
JohnnyP's Avatar
JohnnyP is a decent person
Re: Body Work Help
Gas works too! but you better wash it real good afterwards whatever solvent you use......
Old Nov 1, 2005 | 11:09 AM
NINER's Avatar
Retired
Re: Body Work Help
Do a search. This has been covered in the forum a few times in the last month.
Old Nov 1, 2005 | 11:12 AM
3824's Avatar
Re: Body Work Help
yeah goo gone ... but not goof off ... they are always close to each other on the shelf and goof off will eat though your ****
Old Nov 1, 2005 | 05:09 PM
Tdeal28's Avatar
Tdeal28 is an unknown quantity at this point
Re: Body Work Help
Get a can of Spray Carb Cleaner.......will take the glue right off, then just wash the plastic down with soap and water.
Old Nov 1, 2005 | 06:52 PM
WILLIS69's Avatar
WILLIS69 is an unknown quantity at this point
Re: Body Work Help
3M Adhesive remover. Works like a champ. After that use 3M rubbing compound, then follow that with 3M finishing compound.
Old Nov 1, 2005 | 07:08 PM
jwr689s's Avatar
jwr689s is an unknown quantity at this point
Re: Body Work Help
WD40 works well and won't eat any plastic or paint
Old Nov 1, 2005 | 07:37 PM
kxrider's Avatar
Re: Body Work Help
penut butter and 80 gritt paper
Old Nov 1, 2005 | 07:38 PM
Squidmark's Avatar
Squidmark is an unknown quantity at this point
Re: Body Work Help
yeah, we use fast dry enamel reducer at the detail shop i work at. just wash and wax when your done.
edit: Im pretty sure you can get it at most auto parts stores. Test a small spot to make sure it wont take paint off right away. (it usually wont hurt a cured factory finish)
Brake cleaner works pretty damn good too. I use it all the time to clean the spray-can overspray off my frame without damaging the factory paint.
Old Nov 1, 2005 | 10:20 PM
AzN~BoI_585's Avatar
AzN~BoI_585 is an unknown quantity at this point
Re: Body Work Help
I used goof off...
Napkin Legend
Mar 9, 2013 12:03 AM
joeyt323
Mar 3, 2013 06:50 PM
swtorcredits
Jan 28, 2013 05:51 AM
