f4 f4i swapable parts
Old May 27, 2005 | 04:57 PM
Miltown's Avatar
Whats low down on swapable parts between the two models.
I know the frames are the same
Forks / triples?
handle bars?
rotors and wheels?
Side plastics?
99-03 subframes?
are all of these components the same?
Old May 27, 2005 | 10:23 PM
jowalskiMO's Avatar
jowalskiMO is an unknown quantity at this point
Re: f4 f4i swapable parts
definately forks and triples and handle bars. Almost sure that the other stuff will swap too, but not 100% sure. I'm like 95% sure.
Old May 28, 2005 | 10:37 PM
f4stunna's Avatar
f4stunna is a decent person
anyone else know???? i have an F4 and im about to get an F4i that needs a frame, what else is swapable
Old May 28, 2005 | 11:32 PM
sbc967's Avatar
sbc967 is an unknown quantity at this point
you can swap it all. I have both now. the only diff is the back wheel, you will need the cush drive that goes with the year rim, 99-00 has 5 cush rubbers, 01- up has 6. as far as i know thats it. hope this helps
Old May 29, 2005 | 12:25 AM
clumbsybiker's Avatar
clumbsybiker is an unknown quantity at this point
the fairing stay is different too, because of the different headlight setup, but thats about the only difference that I know of FRAME and PLASTIC wise. If you swap an F4i sub frame to an F4, you will hafta kinda wrestle with the dampner hookups but thats the only issue that me and my buddy had.
Old May 29, 2005 | 09:55 AM
f4stunna's Avatar
what about tanks?? since they have the same frame im not sure? the f4i im gettin doesnt have a tank, i thought they were different but im not sure if it will still work. the only thing i can imagine it would have an issue is with hittin **** underneath.
Old May 29, 2005 | 11:08 AM
Miltown's Avatar
pretty sure the tanks are different because the f4i tank has the fuel pump inside it
Old May 29, 2005 | 07:32 PM
LivingCanvas's Avatar
LivingCanvas is an unknown quantity at this point
you should be able to swap out the fuel pump though. i have an f4i fuel pump for sale....75$
Old May 29, 2005 | 10:31 PM
airprene's Avatar
airprene is an unknown quantity at this point
dude just get on ebay and get a new tank and then you will be done
Old May 30, 2005 | 01:22 AM
sbc967's Avatar
you will need a f4i tank. their is no hole for the fuel pump in an f4 tank. you can get a pump from ebay for around $40 or less. 929 pump works also. call a bike salvage yard and you can get a slightly dented tank with pump cheap.
kawasaki622
Jan 30, 2020 05:44 PM
zx636minch
Jan 18, 2013 12:23 AM
punchinghookers
Nov 19, 2012 09:32 PM
CIX StunnaChris
Oct 29, 2012 01:49 AM
