Complete guide for learning basic wheelies the right way
Old Apr 10, 2008 | 03:04 PM
  #541
R6VP's Avatar
R6VP is an unknown quantity at this point
An R1 wont take much to get the front tire up. I wouldnt clutch that thing in 1st. In fact, i wouldnt even do anything in 1st. It has enough power to jump up nice and smooth in 2nd. I would say keep practicing!! Bring up the RPM's a little more each time while popping the clutch. Keep only one finger on and off the clutch! Listen to the bike more than watch the Tach itself. As it starts to rise, just get into the gas a bit more. DONT CHASE IT!! If it feels like you are, let off and start over. I have stood my R1 up @ 70 in 2nd no problem. A lot of people say start while sitting or other say standing. Do whats comfortable..! Hope this helps.. Sum it up, more RPM's!
ALWAYS REMEMBER, IT DOESNT DO YOU ANY GOOD TO LEARN A WHEELIE IF YOU DONT LEARN TO COVER YOUR BRAKE!!! ALWAYS!!!!!!!!!!!!!!
Old May 18, 2008 | 06:10 AM
  #542
54RR's Avatar
54RR is a decent person
Originally Posted by BS0530
hey everyone... no one has been on the post hopefully someone will reply... im currently new to the site and ive been reading and everyone saids revs it to 15 mph and let the clutch go... however ive tired that and it doesnt pop up! should i go faster or is it that im not doing something right... i have a R1 2002
Man, if u r R1is not getting vertical in first, means one thing, when u r clutching u r not giving it gas. In 1rst you have to give it a tiny amount, well i m going to say tiny so u dont get on u r ***. Or if u cant give it gas while clutching, cluch while accelerating, u r rpm shouldn t be constant when u clutch, it should be rising. In 2nd gear u have to give it much more gas. that s why if u r learning do it in first, more chances of getting vertical. Remember, always launch at the same speed, and correct according to u r bike behavior meaning if it doesn t launch give it a little more gas. Good stunters always tell u to cover the back brake, but from my experirnce, when u begin to have rear brake control, u r past the phase were u lauch the bike to a flip. So my advice is to wheelie a fiddy or a dirt bike first, just to practice rear brake, even then, u wont be totally confortable to use it on the sport bike, cause it s a different game. I dont know if the guys agree but this is the input of a guy chasing BP on a stock liter bike. Good luck.
Old May 19, 2008 | 02:27 AM
  #543
305Stunter's Avatar
305Stunter is a decent person
Angry Re: Complete guide for learning basic wheelies the right way
Hey everyone i'm new here my name is Matt and I'm in FL but anyways I just picked up an 03 CBR600F4I and they already changed the sprockets out the back is 46teeth so I figured 4up and 2down.... now I've been trying to lift it up cuz I wanna get stunting and like seriously get into this sport but i'm havin an issue because i'm not use to having 17k/RMP's my last bike was a 96 Kawasaki ZX-7R and it only had 12k/RPM's.... If anyone can help me I'd really appreciate it I know most of you on this site have F4I's so I figured i'd ask..
Old May 19, 2008 | 03:32 AM
  #544
305Stunter's Avatar
Cool Re: Complete guide for learning basic wheelies the right way
i'm not sure how fast to go in what gear and when to clutch it up or how to clutch it up for that matter I did it tonight and the first time I was in first gear goin prolly like 10mph and then i pulled the clutch in fast and as i was excellerating through i released the clutch and it came up prolly like a few inches then i tried it again and when i popped it up i ended up spinnin the back tire as well so i pulled the clutch back in...... I'm not sure where I should hit this at... i'm gunna try 2nd gear but i'm not sure at what RPM range i should do it!.... if anyone can I'd really appreciate it.....
Old May 25, 2008 | 09:37 PM
  #545
cojack42o's Avatar
cojack42o is a decent person
use 1 finger to clutch it. its alot safer cause you have have more control on your handle bars. if you could use the back brake than go for it. but if your having a hard time clutchn it with 1 finger with the stock levers. try buying aftermarket levers like "pazzo racing levers" i have small fingers and these levers are easy to pull in and ease out. It does spoil your fingers cause once you go back and try clutching it with stock levers you'll have to use 2 fingers to clutch it
Old May 26, 2008 | 03:03 AM
  #546
305Stunter's Avatar
Exclamation Re: Complete guide for learning basic wheelies the right way
I tried clutching it but in second gear and i couldn't get it up..... i'm not sure where to do it at rpm wise.... and yes I have small hands too so those levers are really better?.... also i'm still runnin the stock sprocket someone told me it'll be so much easier after i change them out! But i'm not sure what to do im thinkin 4up/2down?
Old May 26, 2008 | 08:08 AM
  #547
JHIMELLE's Avatar
JHIMELLE is a decent person
Originally Posted by EGONZALEZTR
Whats Up Peoples! Im New Here Quick Question For All I Got An 04 Gsxr600, So In First Gear When Should I Pop The Clutch? And Is It Easier Standing Up Or Sitting?
i have an 05 with a vortex 47 tooth sprocket, stock front and bmc filter. i am no stunter by deffinition but i have no prob getting the bike up at 60 mph max. I used to look at the tach but now i just listen to the engine, slip the clutch, sit back on the seat and it comes up nice and smooth. i learn in first sitting down and when i could bring it up at 15mph and ride it to redline, i moved to second. the throttle on the gsr is to snappy. my buddy 6r is smother than my bike.
Old Jun 10, 2008 | 06:22 PM
  #548
DIRTYROOTS's Avatar
DIRTYROOTS is a decent person
Hi Fairly New 2 The Stunt Seen An Am After A Back Finger Brake 4 Me Cbr900 But Aint Gotta Clue Whre 2 Buy Or Find These Aftermarket Parts. Any Ideas?cheerz!
Old Jun 17, 2008 | 12:38 AM
  #549
Lone Ryder79's Avatar
Lone Ryder79 is a decent person
Hey new here!!
Just want to say what's up to everyone.
Getting a lot of info here.
A lot pf cool peeps in this forum
Old Jul 2, 2008 | 01:03 AM
  #550
kawiboi00 is a decent person
i ride a 600... so getting her to stand up by just pinning it is pretty hard....but ive heard r1 and similar cc bike it you just compress the front and whack it and you can get vertical very smoothly controling it with your rear brake? Correct me if im wrong...?
Old Jul 2, 2008 | 05:23 AM
  #551
GSXR Carlos's Avatar
Professional Work Avoider
GSXR Carlos will become famous soon enoughGSXR Carlos will become famous soon enough
To All You Newbs,
if you don't know for sure, don't give out bad advice!
these people will read you posts and hurt themselves.
Most bikes will wheelie off the clutch, if you're struggling with an R1 it's definitely down to bad technique.
any bike will wheelie, it's all just practice and technique.
so read this thread, then re-read this thread, then practice, then re-read this thread.
Also try and find better riders to ride with and show you how it's done. No amount of reading and typing on here will make you a good rider, just look at my post count
Plus, get some video and post it up on you tube, cos everytime you ask for help you're gonna need it on vid
and welcome to all the newbies
Old Jul 13, 2008 | 06:25 PM
  #552
Gorrila-Stunt's Avatar
Gorrila-Stunt is a decent person
im starting on a cbr 900rr is that to much or should i just take it slow
Old Jul 14, 2008 | 02:06 AM
  #553
phxRRkid's Avatar
phxRRkid will become famous soon enough
*bump*
Old Jul 14, 2008 | 09:45 AM
  #554
phxRRkid's Avatar
i'd say whatever you're comfortable with man, is it your first bike?
Old Aug 1, 2008 | 11:33 AM
  #555
TOE 2 TOE's Avatar
TOE 2 TOE is a decent person
bump nice read
Old Aug 2, 2008 | 10:02 PM
  #556
jtjohns's Avatar
jtjohns is a decent person
I've been slippin the clutch around 10-11 rpms and it flies up in first gear. Am I at too high of an rpm cause I scared the **** outa myself today (felt like I was going to fly off the dam thing). Oh, I'm on a 01 750 with a full exhaust and pc3 if that makes any difference. Also, should I try keep my eye on the tact or should it just be a feel thing.
Old Aug 5, 2008 | 11:28 PM
  #557
biker gal's Avatar
biker gal is a decent person
Smile Re: Complete guide for learning basic wheelies the right way
hey im 4n india im a biker i do drag but now i want to do stunts can u plz tell me what sud i do frst
Old Sep 3, 2008 | 09:53 AM
  #558
Razorbaq's Avatar
Razorbaq is a decent person
I just began learning a few of these things from friends but This info covered a some things I been Missing, Thanks alot Bro!
Old Sep 14, 2008 | 07:07 PM
  #559
KANE>NIN's Avatar
KANE>NIN is a decent person
get a stunt bike (honda f4i or kawasaki 636 are the better) or try learning on a 50
Old Sep 15, 2008 | 01:19 PM
  #560
cassman's Avatar
cassman is a decent person
thanks f4rider, i knew the basics, but your article certainly helped out with some small questions, hopefully they will keep me off the ground...
