need help plsz
Old Jun 14, 2010 | 01:22 AM
ahlik fresh's Avatar
ahlik fresh is a decent person
need help plsz
need help with bleeding the 3rd brake with benjo bolt adaptor 929
Old Jun 14, 2010 | 01:27 AM
OnEWhEeLNEAL's Avatar
NealFoReal
Re: need help plsz
what do you need help with? you need to be a little more specific.
Old Jun 14, 2010 | 02:31 AM
Re: need help plsz
the best way i have found is to not even touch the foot lever , i like to put a clear hose on the bleeder valve on the caliper and leave it open just enough to let the fluid and air come out ..
i loop the clear line up over the seat and down to a catch bottle that way the air bubbles will rise as you pump the hand brake and eventually you see just fluid and no bubbles ..
just keep the reservoir full while you are slowly pumping the brakes so you dont force more air in the system ..
pump at least 3 full reservoirs worth of fluid through the system ...
