Vortex Sprocket help...?
i just got my 525pitch 54 tooth vortex sprocket and i was wondering what i should do to my front sprocket...? any tips or advice if i should go up more infront or down..... its for an 05 cbr600rr.... have stock front sprocket..... please anyone willing to share there sprocket set up....
Re: Vortex Sprocket help...?
when you put on a new sprocket you should put on 2 new sprockets and a new chain unless your new rear sprockets is used and then it wont make much of a difference any way ..
as far as what size front sprocket thats a matter of if you want more gear or not , if you want more gear then go down in the front but if you wanted more gear then you should have gotten a bigger rear sprocket in the first place
i got a 54 tooth sprocket ... its new ... and about buying all new thats what i plan to do.. i want a 530 chain before i install my new sprocket but any tip on how many teeth i should get for the front sprocket....
1 tooth down in the front is roughly the same as 2-1/2 up in the rear
now with that in mind if you put all new chain and sprockets on your bike and decide you need more gear you need to decide quick cause if you wait too long your chain will have already stretched and then just changing the front will cause every thing else to wear faster ....
umm ok i havent mounted the new rear sprocket do i get a new front sprocket too or can i get just a new 54 rear and new chain....? and is a 120 link chain long enought for me to mount it with the new sprocket and have room left over to adjust the tension on chain..?
the chain stretches as you ride and the sprockets wear to match the chain so putting a new sprocket on an old chain will make the sprocket and chain wear faster ..
as far as the amount of links i dont know , i always just order from phil at motoheaven and he knows what size chain to send me ...
Unless you want more gear stay STOCK in the front, Like Roger said if you wanted more gear u should have just bought a bigger rear sprocket in the first place. The good thing is you can always go down 1 in the front for now and than go back to stock later, or vise versa) You should just stay with a stock front, You don't need more gearing than that just to hit bp.
Also if you got a 525 pitch sprocket you want the same pitch chain. (I see above you said u have a 525 pitch sprocket and you want a new 530 chain)
like i said before when you change you should change both sprockets and the chain , you dont have to but it will last alot longer if you do ..
The chain stretches as you ride and the sprockets wear to match the chain so putting a new sprocket on an old chain will make the sprocket and chain wear faster ..
+1
it's a good idea to match the pitch of the chain with the pitch of the sprockets , you can us the 520 and the 525 as long as the sprockets are the smaller of the two but i dont think the 530 will work with any thing other then a 530 ...know what i mean ?
