Third brake master options....
Hi,I have a question what stock style master should I go with ?Someone told me stick with the 929 front master and flip it .He says its the best one too use ?Any comments or opinions on that ?This is for an 01 929 Thanks
Re: Third brake master options....
929 master is what i use for a front brake master only because im used to it not cause it's better as a matter of fact it is too on/off with no feel ,a gsxr radial master is a waaaaaaaaaay better master for a hand brake or a front brake and if you are baller then a magura billet is the shiznet
i think 05 and later were all radial , the easiest way to tell if it is a radial master is the direction of the piston , older style non radial masters push the piston to the side when you pull the lever in but a radial master will push the piston back when you pull in the lever
the r1/r6 brembo(I think its 04 & up) is a good master if youre not ballin and cant afford a brembo or magura. although -sketchy- on here has maguras for cheap compared to market price - if he still got them in stock.
100%
