hand brake has no pressure!!!!need help
Old Sep 5, 2009 | 11:17 AM
CrabbyPatty's Avatar
CrabbyPatty is a decent person
i just recently installed a brembo handbrake set up. im a newby to this so i need some help. I have it set up to where i can still use my foot brake also. So i have a brake line coming from handbrake down to the footbrake set up. How do i get pressure into that line. im so lost!
Old Sep 5, 2009 | 11:20 AM
SUPERDAVE's Avatar
HOOD CHAIN GANG
SUPERDAVE will become famous soon enough
Re: hand brake has no pressure!!!!need help
you have to have your m/c right side up with the bleeder screw ontop of the pump.Then usea vaccume bleeder on the rear caliper and suck the brake fluid till it comes through with no air, and then go back ontop and manually bleed the m/c.
Old Sep 6, 2009 | 02:16 PM
how do you bleed the MC on top?
Old Sep 6, 2009 | 03:40 PM
repsolstuntin1's Avatar
repsolstuntin1 is a decent person
disconnect the line from your hb to your master cylinder and fill up the resevoir on your hb and let it gravity feed when it starts to drip hook it up and pump the hb over and over again till it gets pressure with out a vacum bleeder your going to be there a while.. its a bitch.
trdtruck26
May 23, 2013 07:56 PM
greenhornet347
Mar 24, 2013 12:22 AM
f4i knight
Feb 26, 2013 03:06 PM
CRFstuntin
Jan 7, 2013 10:06 AM
OneWheelRegulator
Dec 2, 2012 01:25 AM
