636 help
Old Feb 3, 2009 | 06:09 PM
johnnyrocket's Avatar
johnnyrocket is a decent person
636 help
So i just picked up a 03 636 that im going to stunt. this may be a stupid question but it has a power comander 3 on it and im wondering how this will affect with stunting if so i do i set it back to normal before i remove or do i just remove it and everything goes back to stock??? 2nd can anyone give me the links for the kleen air mod thread and the idle thread... also anything else i should kno before my build let me kno all iv ever had is hondas. thanks
Old Feb 3, 2009 | 09:43 PM
Re: 636 help
ok so i just fired her up and shes got a pretty good valve tap noise... the motor feels strong besides that. does anyone kno if this can be solved by adjusting the valves...
Old Feb 4, 2009 | 06:48 PM
Re: 636 help
anyone....
Old Feb 4, 2009 | 07:10 PM
cjoec01's Avatar
Bacons Hot, Need a Spot
cjoec01 has much to be proud ofcjoec01 has much to be proud ofcjoec01 has much to be proud ofcjoec01 has much to be proud ofcjoec01 has much to be proud ofcjoec01 has much to be proud ofcjoec01 has much to be proud ofcjoec01 has much to be proud ofcjoec01 has much to be proud ofcjoec01 has much to be proud of
Re: 636 help
https://www.stuntlife.com/forums/443...+kleen+air+mod
I got an 07 and the valves are noisey,tick/tap. i read on here that it's normal for the Kawasakis.
Old Feb 5, 2009 | 07:30 PM
Re: 636 help
thanks now im tryin to find the thread on how to diable the kill switch... thanks
Old Feb 5, 2009 | 08:35 PM
sdfkillz's Avatar
Re: 636 help
drill a hole and stick a cotter pin or something in it. i just headed up a small diamter nail and pushed it through then used a bobby pin.
Old Feb 5, 2009 | 08:55 PM
Re: 636 help
sweet thanks
Old Feb 5, 2009 | 10:57 PM
Dstunts's Avatar
Dstunts is an unknown quantity at this point
Re: 636 help
if you open up the switchblock then cut and join the two wires connected to the kill switch button this will complete the circuit and disable the switch
Old Feb 5, 2009 | 10:58 PM
Dstunts's Avatar
Re: 636 help
if you open up the switchblock then cut and join the two wires connected to the kill switch this will complete the circuit and disable the switch
Old Feb 6, 2009 | 04:33 AM
Re: 636 help
sweet i like this better than using a nail
Old Feb 16, 2009 | 01:16 AM
zxonone's Avatar
zxonone is an unknown quantity at this point
Re: 636 help
It will probably get quieter as it warms up. Mine did anyway. What kinda mileage you think shes got. I would probably at least check the valve adjustment.
knowlzy0791
Jul 26, 2013 11:56 AM
escort1991
Mar 12, 2004 10:53 PM
