hand brake set up... duel or single???
is there any dis advantage to a single caliper hand brake as apose to a duel? i have the chance to get a full throttle hand brake set up 4 a great price and i was just curious.
Re: hand brake set up... duel or single???
What Full Throttle Set up you going with? the adapter or the actual master? Ive had both of them and they are ok, the actual master being the best 1 or the 2, also depends on the brake master you run thought too.....ont he new build it came with the hohey 4 piston so Im gonna run that with the Magura 13mm
, even if it didnt Ive been wanting to give that set up a try thats what eveyone is going to tell you to go with more than likely
OneWheelRegulator
Dec 2, 2012 01:25 AM
greenhornet347
Oct 15, 2012 02:26 PM
