Changing f4i throttle cables
Re: Changing f4i throttle cables
I use 2 small flatheads. Took me about 5-10 minutes the first time, and 5-10 seconds now.
Use one screwdriver to push the cable so it lines up with the slot, then use the other screwdriver to push the round thing out of the hole
+1 took me like 1/2 hour the first time but now I can do it in a couple mins
Lord I hate working with them throttle cables. I just put them on after replacing the starter motor and it took me a ****** hour
I have times where it will take 5 minutes and then like the other day took an hour. I have a tool which has a hook on it - I used that to hold the cable initially and get it near the hole where it mounts and then used a flat head to push it in while then taking that hook to pull the cable up so it lines up properly lol. Do work son. Youll get it. Its not really a hook - more like an l shaped screwdriver without that phillips at the end lol. I dunno what its actually called tho but yeah you get the idea.
I have times where it will take 5 minutes and then like the other day took an hour. I have a tool which has a hook on it - I used that to hold the cable initially and get it near the hole where it mounts and then used a flat head to push it in while then taking that hook to pull the cable up so it lines up properly lol. Do work son. Youll get it. Its not really a hook - more like an l shaped screwdriver without that phillips at the end lol. I dunno what its actually called tho but yeah you get the idea. Re: Changing f4i throttle cables
i only use the pull cable, i never use the return (i take that bitch off and keep it for a spare). i just switched out my boys not to long ago, took me about 2 minutes.
"Keep Your F4i's IDIOTS"
I have times where it will take 5 minutes and then like the other day took an hour. I have a tool which has a hook on it - I used that to hold the cable initially and get it near the hole where it mounts and then used a flat head to push it in while then taking that hook to pull the cable up so it lines up properly lol. Do work son. Youll get it. Its not really a hook - more like an l shaped screwdriver without that phillips at the end lol. I dunno what its actually called tho but yeah you get the idea.Hmmm
i use a screwdriver or 2 and a few beers
