highchair/spreader help?
trying to get highchairs and spreaders down. but i cant do 1 finger on the clutch and 1 on the brake. i can for for everything else but these. it seems to really pull the bar out of my left hand. even tried to clutch then switch to the brake but that didnt work. can ride them out but cant get anything close to idle cause i dont have anything on the handbrake.
are my levers not set up right or is it something that will just come......
Re: highchair/spreader help?
I have some pretty scrawny arms and have no problems with 1 finger on each lever
these were when i was hooking it up last year. i did cut the brake about 1.5 inches shorter but thats it...
i can 1 and 1 for seat standers n stuff easy. just seems with speaders n highchairs that hand doesnt hold on as good?
Just gotta keep practicing
I still can't rock idle spreaders, then again I don't practice them much..
But I have no problem doing idle SS's
Gotta work on your arm/hand strength, so you can hang on with only your ring and pinky fingers
But thats only because hwne I'm starting to stall out, if I try to let go and grab onto the clutch, I **** up
edit: then again I guess im just weird... I cover my clutch on the freeway in 3rd gear lol
Nah.....you're not wierd...lol...I think it's good practice to cover it, but if ya can't hold on.......whatcha goona do? LOL
