Acerbis light hookup help
Old Feb 17, 2008 | 10:46 PM
Stubbz's Avatar
well i had my acerbis diamond headlight wired on and working fine and i was tryin to find the wire that runs to just the highbeam lights so when i stunt in the lot i can turn the lights off but no matter what wire i put my test light on if it lights up on highbeam it lights up on low as well. anyone know where the hell that damn highbeam wire is and where to tap into it?
i took off the switch assebly and mount the wires that run to the light rocker but neither of them make the test light light up, i'm lost.
Old Feb 17, 2008 | 11:47 PM
Towlieee's Avatar
Re: Acerbis light hookup help
Use a multimeter to check which wire is hot with only the high beam on
Old Feb 18, 2008 | 06:36 PM
Stubbz's Avatar
none of um lol. wtf?
Old Feb 18, 2008 | 06:42 PM
I Ran both the Lights From the Acerbris to One Plug
on the Bike.... I have High beam And No Low Beam...
Old Feb 18, 2008 | 08:49 PM
Stubbz's Avatar
well where did you splice it in? no matter what i try they both light up. hook me up with a pic man please, i'll pm you my number tex me a cell phone pic or suntin idc
Old Feb 18, 2008 | 09:30 PM
Towlieee's Avatar
Theres what
3 wires going to each light from the factory? Regular old 3 prong harness?
So its 1 ground, 1 high beam 12v+, and 1 low beam 12v+...
If you have a multimeter, check which one shows +12v with the high beam on, and doesn't show 12v with it off..
If you don't have a DMM, just hook the light up to 2 of the wires, and switch the wires around tell it works...
It can't be THAT hard! lol
edit: and just splice it where your factory lights hook up.. Way easier then trying to find some random place on the harness to splice it in..
There could only possibly be 3 wires per headlight
Old Feb 19, 2008 | 12:23 AM
TL MILLER's Avatar
TL MILLER is an unknown quantity at this point
dONT FORGET THAT YOU NEED THE BIKE RUNNING TO CHECK THE WIRES FOR VOLTAGE. THE 636 LIGHTS STAY OFF UNTILL YOU START IT. I CAN CHECK THE WIRES WHEN I GET HOME TOMARROW IF YOU STILL NEED HELP
Edit: left the caps on
Old Feb 19, 2008 | 08:43 PM
Stubbz's Avatar
good poin t i'm bettin thats my problem cuz i dont have the tank hooked up so can't run it, but when i had it wired up it would light up with just the key turned on so idk. i'll try it when i get my exhaust back on and get some gas in the tank
Old Feb 22, 2008 | 11:57 PM
TL MILLER's Avatar
do you stull need help? im going to be working on the 636 tomorrow
Old Feb 23, 2008 | 08:15 AM
Stubbz's Avatar
well right now my forks are sent out to fullthrottle for the sleeve so i have the bike all apart but in a week or so when i get um back i'll be hookin the light and all back up. gonna try and get a voltmeter to test the high beam wire so i can finish up all the wiring and mount my tank and gpr on for good.
in other words yeah i still need help haha
someone was gonna take a pic for me and send it to me on what wire they ran the lights to but they haven't yet
Old Feb 23, 2008 | 04:10 PM
TL MILLER's Avatar
Ill get it today
Old Feb 23, 2008 | 05:01 PM
Stubbz's Avatar
cool thanx
VXscOOter
Jun 22, 2013 02:31 PM
VXscOOter
Jun 22, 2013 02:29 PM
njstunt855
Dec 18, 2012 12:43 PM
njstunt855
Dec 5, 2012 04:34 PM
shugga
Jul 26, 2008 11:26 AM
