f4i help
Old Feb 4, 2008 | 10:29 AM
dave-c's Avatar
dave-c is a decent person
f4i help
hi everyone i have just started stunting .
i have an f4i but when it was on its side yesterday a load of smoke came out of somewhere then when i try starting it it just makes a clickin noise and wont start does anyone know what the problem is and how to fix?
Old Feb 4, 2008 | 01:21 PM
E-Loc540's Avatar
540 BOYZ SUMO STUNTER
E-Loc540 is an unknown quantity at this point
Re: f4i help
hydro lock....oil in your cylinders, you cant compress a liquid...there are many threads around here on this same issue. They will tell you your steps to recovery
Old Feb 5, 2008 | 05:27 AM
dave-c's Avatar
Re: f4i help
thanks i have read all the threads but still cant find how to get it unlocked
Old Feb 7, 2008 | 10:59 PM
2kgixx's Avatar
2kgixx is an unknown quantity at this point
Re: f4i help
try boosting the battery, and if that doesnt work it probably hydro locked
Old Feb 11, 2008 | 09:37 AM
ADJMART1's Avatar
ADJMART1 is a decent person
Re: f4i help
pull the plugs out,turn it over and let the oil shoot out,put the plugs back in and start it up.
Old Feb 11, 2008 | 10:36 AM
kosi28's Avatar
kosi28 is an unknown quantity at this point
Re: f4i help
these guys are on the right track if its making a clicking sound then it is more than likely the battery is shot i recommend testing it first with a battery tester if you dont have one take the battery out and take it to walmart they will test it for you if the battery is good then do what adjmart1 said that exactly how you clear a hydro lock pull the plugs out and turn it over but i recommend placing a rag over the plug ports so oil doesn't shoot everywhere.!!!!!!!!!
Old Feb 11, 2008 | 12:38 PM
E-Loc540's Avatar
Re: f4i help
^^^???? it makes sense that your bike is hydro locked, what are the odds of the battery/starter going out at the same time as the hydro lock taking place
Old Feb 11, 2008 | 12:43 PM
kosi28's Avatar
Re: f4i help
its close to none..... its either one or the other which is way i said 1st check the battery if its not that than its more than likely hydro locked
Old Feb 11, 2008 | 02:27 PM
f4ibry's Avatar
u been huffin?
Re: f4i help
i think id check the hydrolock first.....dont try n bumpstart it!
jut pull the pluggs and stand back itll shoot!
morrow85
Aug 25, 2013 02:59 PM
Jay Rodriguez
Jan 27, 2013 03:13 PM
