F4I DB Brake Lines?
Old Jan 22, 2008 | 09:55 PM
Stubbz's Avatar
F4I DB Brake Lines?
on an F4I with DB bars what length steel braided lines do you guys run in order to reach the db bars but not be overly long? and how do you run them to one caliper with a dual banjo bolt then wrap around the other side or split in the center with a T style banjo? my buddy is wondering, F4I's come stock with a T my 636 goes to one side then splits and wraps around to the other
Old Jan 23, 2008 | 01:21 PM
Re-Micks's Avatar
YUT UGH
Re-Micks is a decent person
Re: F4I DB Brake Lines?
run a double banjo out of the front master, two long lines run one to each caliper... measure with a tape measure from caliper too bars (my 636 is 33" to the right caliper and 40" to the left caliper) and that depends on rise of bar and order them up through HAI
Old Jan 23, 2008 | 08:43 PM
Stubbz's Avatar
thanx, i heard from somoene else to run one to one caliper and add the double banjo from there and wrap a seperate line around and over to the other caliper, thats the way the stock 636's are. i figured thatd be less lines hangin around as well. i have a place i can get them at dealer cost so not worried about ordering them from HAI. but thanx anyways. anyone else have any input?
b16_rex
May 27, 2025 06:05 AM
blayl
Dec 3, 2012 02:17 PM
blayl
Nov 29, 2012 03:23 PM
Greenman203
Nov 21, 2012 08:56 AM
SBS Pez
United Kingdom
Nov 6, 2012 04:04 AM
