master for hand brake
Re: master for hand brake
it's the size that matters... that's an axial master, and therefore, you should need like a 11 or 12mm one... If you have a radial master, you can go for a bit bigger, like 13mm or 16mm
I had a problem fiting my master with stock f4i clipons but i had a zx-7 clutch master. i ended up grinding **** to make it work. Im sure this will not help u but its my
kntmare181
Feb 14, 2013 01:00 AM
OneWheelRegulator
Dec 2, 2012 01:25 AM
