scrape help
Old Oct 22, 2006 | 10:41 PM
Seal Clubber's Avatar
Seal Clubber is an unknown quantity at this point
scrape help
can anybody break down the pull in the clutch method to scrape for me?
Old Oct 22, 2006 | 10:50 PM
aw0n0's Avatar
Re: scrape help
hmmm, im not sure what you mean exactly, but since im on a mission to answer everyones questions tonight, ill try to answer. you probably want to use 2nd for this, get a wheelie up to the bp or slightly behind it and pull in the clutch. you should slowly fall back, apply gentle rear brake if you come back towards the bp you used too much brake. use such a slight amount of brake you only come back a tiny bit, until you hear a loud scraping noise, then give it a healthy amount of rear brake to come back down below bp and release clutch and give gas so you dont come down hard as ****.
Old Oct 22, 2006 | 11:03 PM
Re: scrape help
you think 2nd will be better than first? I've never scraped in 2nd
Old Oct 22, 2006 | 11:08 PM
aw0n0's Avatar
Re: scrape help
well 2nd is smoother and you have more speed to slow it down slowly and get a more controlled scrape. but by all means learn what you feel comfortable with.
but on a side note, i would work on coasters and idle wheelies to get more comfortable with the bike, then scrapes will come easy.
Old Oct 22, 2006 | 11:13 PM
Re: scrape help
thanks man thats what i thought
Old Oct 22, 2006 | 11:23 PM
aw0n0's Avatar
Re: scrape help
no problem
Old Oct 22, 2006 | 11:46 PM
kj's Avatar
kj
Re: scrape help
Work on long, smooth coasters.... then just let em come back a little further each time till ya gently touch.
Old Oct 22, 2006 | 11:54 PM
Re: scrape help
you just get to balance point grab the clutch and ride the rb or what
Old Oct 23, 2006 | 12:07 AM
kj's Avatar
kj
Re: scrape help
Just my opinion, but I wouldn't try scraping without learning coasters first... there's alot of control there that you need to be familiar w/.
Are you already slowing wheelies down w/ steady throttle and riding the brake?
If not... learn that first.
After you can slow one down to almost a stall.... then get some speed, get back to just before you start to slow (bp), then give a blip of throttle and pull in the clutch as you feather the brake so ya don't loop.
Ya wanna keep it a little behind balance point so it dosen't slam down.
Old Oct 23, 2006 | 12:08 AM
Vetter's Avatar
Squid Extradoinaire
Re: scrape help
for coasters yeah...
get it up and gain speed. get alot of speed. coasters are easier fast. get it right at bp...that sweet spot. pull the clutch in and coast. keep foot on brake.ride it behind bp. at first youll ride them way behind bp and slow down real quick but its all practice. if you fall to far back use rb to get it back into that sweet spot. gotta be good with the brake.
coasters will help your footbrake skills alot. once you get good with it scraping on brake will be nothing.
Old Oct 23, 2006 | 12:18 AM
Re: scrape help
yeah I can slow wheelies down alright in first I don't really ride the brake though just taps I can't slow them to a stall yet. I've tried to grab the clutch but I think I'm going way to slow because it only stays at that sweet sot for a second
Old Oct 23, 2006 | 12:25 AM
Vetter's Avatar
Squid Extradoinaire
Re: scrape help
k lemme reprase it...
when u do a coaster when u pull in the clutch the bike should fall backward. if you didnt get on brake youd scrape.
i think going slow isnt your problem i think you werent far back enough on the clutch pull.
k...do a fast 1st gear wheelie...get the bike to start slowing down...in other words get it behind bp. pull in clutch mean while slightly ride brake. i cant really explain it an better. i guess i just feel it.
Old Oct 23, 2006 | 12:33 AM
Re: scrape help
thanks for all the help you did break it so that I think I understand I appreciate it
Old Oct 23, 2006 | 04:34 AM
bruno_z's Avatar
Re: scrape help
don't pull the clutch in when in bp, do it little behind, it's safer because if you do it in bp and mess with brake you'll slam down, and I doubt that you'll let the clutch out...as far as your slowing it down you can pull in the clutch safely...
Old Oct 23, 2006 | 06:32 AM
Jon PBR's Avatar
Jon PBR is an unknown quantity at this point
Re: scrape help
I just learned dragging on the 12 bar and I would definately suggest learning coasters first. Once you got coasters then scraping will be nothing.
Old Oct 24, 2006 | 11:38 PM
2lo4u2c's Avatar
2lo4u2c is an unknown quantity at this point
Re: scrape help
is it better to try sit down coasters first?
Old Oct 24, 2006 | 11:40 PM
Re: scrape help
I can do them now for like 100 feet, everything is easier for me standing up
Old Oct 25, 2006 | 01:18 AM
Vetter's Avatar
Squid Extradoinaire
Re: scrape help
at least your actually doing them they will get better and better. remeber an ideal coater is on little or no brake. i tap mine back into bp. the slower you go the furthe back you need to be...its a fine touch young homie but start coming into them faster and faster.
2 weeks time all youll be doing is coasters at the spot. :YEAH
Old Oct 25, 2006 | 01:46 AM
martino's Avatar
wheres all the fat girls
martino is a decent person
Re: scrape help
hows this better than just scraping with the clutch engaged?
ive always just scraped without touching the clutch
Old Oct 25, 2006 | 01:47 AM
Vetter's Avatar
Squid Extradoinaire
Re: scrape help
after he has good brake control he wont have the possibilty of wobbles from far back enigne brake ?
