need Bp help.
how do i know when i hit my Bp in a staggered wheelie- 2 should my foot be over the back break doin wheelies at 80plus MPH-3 I cant keep my RPM,s down in a long wheelie some 1 said that my front wheel wasnt up high enough but when i lift it higher the bike whoobles an it feels like it wants 2 flip back on me what am i doing wrong or not doing at all. help me please..........
Re: need Bp help.
Re: need Bp help.
"try to drink a glass of water with you hand jerking back and forth, it's not very easy"....
lower tyre pressure..blah blah blah.. wheelie how to.. blah blah see what your not doing correct... blah. suh-en suh-en good luck.. blah slow down.
Re: need Bp help.
Re: need Bp help.
Re: need Bp help.
Dood if you can clutch it to 12 catch it with the brake and find the bp with the throttle then fck yeah... go for it. I already told you how to maintain speed.. I think you just have to practice.
Re: need Bp help.
If you have a large sprocket it will help,turn up youre idle to about 3g rand ,from a stopped sitdown position clutch it up cover the rear brake,
keep your focus on youre front forks (when they are level w/ ground its at BP) after a while u will catch idle , it will feel like the bike is stuck in the position w' no throttle or brake input,it also will wobble,just move your hips,body in the direction it wobbles then counter balance. I started out with like under 10 psi ,now i keep a lot of pressure for workin on steering/circles. You most likely will loop it to the bar at first but at least from sitdown if u clutch it to hard you always can reach your feet down and your standing on the ground ,or just catch it with RB right before the bar/tail. ((if u hit the bar to hard and it has a serious wobble, be ready to bail or run behind it cause that cage could land on youre foot ,and it will crush it,but after that happens your reflexes know not to let it happen again)).. ,,,, OH,& of course u should be covering the brake at 80mph ,but u probobly shouldnt be up in a wheelie at 80 yet ,(JMO)
Good luck man
Good luck man
Re: need Bp help.
Then first get a sprocket at least 20+ ,a cage,bar and after u got a feel for RB a handbrake. my bike doesnt buck..? if its at BP on the idle its real smooth if im beyond BP on the RB it might do a buckor2 before it stalls..
Re: need Bp help.
