Balanced rear rim?
Balanced rear rim?
Im wondering if not balancing my rear rim/tire will make a difference for say 50mph wheelies on the streets and such.
I know it wont make any difference in the parking lot, but what about higher speed wheelie wobbles?
Re: Balanced rear rim?
how do you tighten the stem bearings? is there a post of it around here? mine are mad loose and i keep riding wheelies on it cuase the stealership is closed when i have time to do it
#1: Take the top tripple bridge off (ignition holder) u gotta loosen up the bolts on the left n right that clamp onto the forks and the center nut.
#2:now under there is a thin spacer/locker inbetween two spanner nuts, bend the
lock notches straight then take off the two spanner nuts. (screw driver "flat head"+ hamer + chizzle effect) will work with removing these spanner nuts
#3: Now the best bet is to susspend the front in the air with tie downs warped arround the front of the frame on both sides then lift the front wheel off the ground from the celling.
#4: now have a friend stand infront of the bike bent down holding the front wheel firmly pushing back and forth while lifting the front wheel and u chizzle tighten the lower spanner cup till u worked out the play in the stem and tighten it just alittle over that.
Its best to have a friend that puts alot of effort into things to help you with this, cause it sucks putting everything back together and then testing it and it clicking again.
iRiEsTuNtAh!
Jan 20, 2013 10:35 PM
stuntin'_cbr
Dec 6, 2012 04:59 PM
