HB issues!
HB issues!
ok so I know this has been asked a million times. I have a 02 gsxr 600 and want a handbrake. I was going to order a gp tech kit but then everyone started saying that their junk and they will start to leak after a while, and they are not strong enough. Is all this bs or what cause i really wanna buy a kit asap but am getting irratated and confused trying to figure out what kit to buy. Or should i just get te full throttle kit which i really dont wanna do if the gp tech one works just as goo and is cheaper.Thanks
Re: HB issues!
GP TECH = headaches
Fullthrottle = awesome.
if ur cheap and u have more time then money, get the gp tech fitting, i personaly have had no issues with my gp tech fitting but some people just don't posess afro enginering degree like me. fullthrottle is the way to go if u can afford it
Re: HB issues!
I think the key is installing it correctly the 1st time preventing any leaks and then bringing it somewhere or if you have access to a suction type bleader that attaches to an air compresser to bleed it that way. Bleeding by hand or the cheap pump method i just don't think cuts it. If you have air in your lines no handbrake will work correctly. Also use high temp break fluid 450+degrees. Having cheap break fluid that breaks down with a lot of use will make your hand brake go soft also.
Re: HB issues!
ordering the gp tech today, thanks for the advice
since it is such a tight tolerance, IF there is any problem with leaking, which i have never had, you can simply wrap a hose clamp around the GP tech adapter and tight it, problem sovled. I did that on my 03 Gsxr just for safety sake!
Re: HB issues!
The piece fits in there really tight but I put a hose clamp around mine too just to make sure it never moved.
Re: HB issues!
here is another alternative...works great and less expensive than the gptech...
https://www.stuntlife.com/classified...cat=500&page=1
Re: HB issues!
how is that cheaper that what gptech fitting costs
Re: HB issues!
and if u buy multiple adaptors, the first one is $35 shipped, and each additional adaptor is $30 shipped. so if you ordered (2) from me, it would cost you the same $ as (1) gptech adaptor.
Re: HB issues!
Originally Posted by Ed LegionST
my bad on gptechllc.com pg techs website they retail for $55 last time i was on there it was over a year ago and they were $35 sorry im a dumb ***. should of checked the facts first
Re: HB issues!
Originally Posted by r6nitup
just a quick question... how would that fitting work on my 05 r6... the res. is pressed in with an o-ring to seal it... not screwed on at the bottom like the others
