rear tire spins
Old May 23, 2006 | 06:59 AM
nobody850's Avatar
nobody850 is an unknown quantity at this point
rear tire spins
Hi there
I have some difficulty lifting the front wheel! I have a 2003 Yamaha R1.
I am trying power wheeles , from 1st gear but every time I hit the gas the rear tire only spins and the front never lifts ( they are new tires Michelin powers ) what to do?
Old May 23, 2006 | 07:41 AM
Re: rear tire spins
Lean back more, and start using the clutch to wheelie.
Old May 23, 2006 | 07:50 AM
nobody850's Avatar
Re: rear tire spins
Thanks for your replay
I lean far back as i can and i use the clutch but the same thing happens the tire spins.
Old May 23, 2006 | 08:19 AM
KF_Chris's Avatar
KF_Chris is a decent person
Re: rear tire spins
make sure the tire's heated up a little and mae sure that plastic coating that comes on new tires is off. you can kill both with a burnout so have fun!
Old May 23, 2006 | 10:08 AM
Re: rear tire spins
How much air pressure is in your rear tire? Try around 25 psi.
Old May 23, 2006 | 10:18 AM
DBOUNCE1's Avatar
Re: rear tire spins
then after you try that..... try typing in a normal font
Old May 23, 2006 | 10:53 AM
KF_Chris's Avatar
Re: rear tire spins
you shouldn't have problems clutching up with stock tire pressure.
Old May 23, 2006 | 11:04 AM
blacklincoln's Avatar
blacklincoln is an unknown quantity at this point
Re: rear tire spins
R1, pilot powers and no whoolie? thats really strange are you riding on gravel?
i have those tires and they never slip..
ya try burnin them for a few, theres no way theyll slip then..
Old May 23, 2006 | 11:10 AM
Paul's Avatar
Paul is an unknown quantity at this point
Re: rear tire spins
You may be poppin the clutch out to hard,try just giving it a little slip instead.Those michelins shouldn't be spinnin on ya though.
Old May 23, 2006 | 11:56 AM
DENIRO600's Avatar
20%OVER HONDA&YAMAHA PART
DENIRO600 is a jewel in the roughDENIRO600 is a jewel in the roughDENIRO600 is a jewel in the roughDENIRO600 is a jewel in the rough
Re: rear tire spins
Stay in it and lean back a little. Tire smoke into wheelie. Five years ago it was a nice trick. I think somebody use to call it "THE MAD MAX" First gear five mph clutch to full throttle and hold on.(This is to be done in one fluid motion) Kind of like bouncing a six hundy(with stock gearing)to stand-up in third gear on the e-way.
Old May 23, 2006 | 11:58 AM
NYCr6Nukka's Avatar
NYCr6Nukka is an unknown quantity at this point
Re: rear tire spins
i have 02 r1 with mich pps.............you doing something wrong my front comes up when i need it to and when i dont
Old May 23, 2006 | 02:25 PM
SAMBO's Avatar
Re: rear tire spins
or maybe you are on a slick surface
Old May 23, 2006 | 02:37 PM
TheRomanSF415x's Avatar
Re: rear tire spins
yea iono why youre not doin a power wheelie just from powerband.
just roll on the throttle from a stop you have a liter bike it should do the work for you.
Old May 24, 2006 | 01:18 AM
Reeff's Avatar
Reeff is an unknown quantity at this point
Re: rear tire spins
the clutch and gas have to work togeither not agianst each other.Try just slip the clutch
Old May 24, 2006 | 10:27 AM
DBOUNCE1's Avatar
Re: rear tire spins
i think he left us
Old May 24, 2006 | 02:32 PM
Nikoli's Avatar
Nikoli is an unknown quantity at this point
Re: rear tire spins
your deffintly giving it way too much gas, just hit the throttle quick to raise it than throttle on to plane it out, way too much throttle at the start and yea, your tire will spin
hondacrf150f1
Dec 3, 2012 10:04 AM
JerZey
Nov 12, 2012 12:06 PM
greenhornet347
Oct 15, 2012 02:26 PM
ProzaK
Reckless Methods
Oct 13, 2002 01:52 AM
ftrain
Oct 10, 2002 12:03 PM
