'06 636 Wheelies...HELP!
Ok, I am like 6'6" and weigh about 190...I am fine with first gear wheelies and all that "starting off" type shizz. Anyways, is there ANY way I can get the bike up on the freeway doin like 60? its kinda pissin me off, ive tried clutchin/power, everything, I need like MPH/RPM range suggestions. Thanks!
Re: '06 636 Wheelies...HELP!
you should be able to bounce it up in second or third. I suggest that you clutch it up cause its the easiest way to control it. in second I would bring it up to around 35 or 40 and then cutch it up and you'll polly be right around 60 when you get to the BP. In third start at like 45 or 50 and clutch and bounce it at the same time.
that the best I can help......practice is the KEY!!!!
Originally Posted by suicidl
its because the new 636's have slipper clutches. they are garbage
isn't the slipper clutch only engaged when down shifting fast, to prevent the engine brake from locking up the rear wheels?
Just practice more dude, clutch it up in 2nd at 45, and you should be rocking 60mph wheelies easy!
you need more speed/rpm before it will come up high.
the power comes at high rpm only, like over 8 or 9 grand.
Do this and it will work in 1, 2, 3 and 4th, yes 4th and i dont mean little floaters. I mean it will flip over in 4th, all throttle no clutch, if you wait till
you exceed 195 km/h. oh yeah, stock gearing too.
if stock you need to bounce and clutch to get it up to bp in 4th...so I wouldn't really say it will loop just from throttling it...
i have a 05 636 i wheelie 2 and thri d easily 2nd take it up to 7 ot and let off boucne and get back on when teh suspension start comin back up u could ride that **** for a while. for 3rds u nned to do teh same but at about 8 to 9 grand teh coem u easy
