keepin the front up
Old Apr 7, 2006 | 01:45 PM
EDUBon1's Avatar
EDUBon1 is an unknown quantity at this point
keepin the front up
quick question, what do i have to do to keep my wheelies going like once it comes up do i keep the same amount of throttle it took to get it up, apply more or what, startin ta get frustrated with just beling able to hang one for 100 ft, the type of bike I'm using is an F2 with a 48t rear. any help would be great would be better if someone was from MD/DE to give some on sight help.
Old Apr 7, 2006 | 01:50 PM
HJT's Avatar
HJT
HJT is an unknown quantity at this point
Re: keepin the front up
just be smooth with the throttle..... set it back slow at first.... and always ALWAYS cover the brake when you are learning...... .... hope that helps.....
Old Apr 7, 2006 | 01:54 PM
Suicidl's Avatar
WWW.Sickinnovations.com
full throttle :YEAH
Old Apr 7, 2006 | 01:59 PM
EDUBon1's Avatar
full throttle .........somethin about thats just has loop written all over it
Old Apr 7, 2006 | 02:03 PM
750 stunna's Avatar
+1
Old Apr 7, 2006 | 07:22 PM
EDUBon1's Avatar
ttt
biotches
Old Apr 7, 2006 | 11:25 PM
silverstunterR6's Avatar
Try praticing just clutching it up while leaning back until you feel it stay up with little to no throttle. Than start adding throttle to hold it up. Take it slow youll get it in not timeif you take your time.
Old Apr 8, 2006 | 05:08 PM
EDUBon1's Avatar
so it don't matter about the weight of the steel frame
Old Apr 8, 2006 | 06:07 PM
A little,
but if you use your weight youll get used to how high it has to be
Old Apr 9, 2006 | 03:23 PM
OhFourR6's Avatar
OhFourR6 is an unknown quantity at this point
hey silver r6 is the balance point on an r6 high? or what
Old Apr 9, 2006 | 04:10 PM
It feels higher than anyother bike i've riden
Old Apr 9, 2006 | 04:12 PM
Reeff's Avatar
Reeff is an unknown quantity at this point
The further back you lean the lower the balance pt. is.If yer huggin the tank the bp will be hella high.you pretty much want ta be at a 90 degree angle ta the bike ta balance it out make sence
Old Apr 9, 2006 | 07:03 PM
Ando's Avatar
Ando is an unknown quantity at this point
^^hmmmm thanx for that that - i might try leaning back a bit more
Old Apr 9, 2006 | 08:28 PM
r6nitup's Avatar
r6nitup is an unknown quantity at this point
on my 05 r6 it looks like in pics that the forks are always parallel to the ground
Old Apr 11, 2006 | 10:22 AM
EDUBon1's Avatar
to da top
Old Apr 11, 2006 | 12:23 PM
djhex36's Avatar
djhex36 is an unknown quantity at this point
just look at "reeff"s avatar, you can see how his body is 90 deg to the ground, basically if he were to put his legs down, he'd be standing up straight, and his bike looks like its balanced , he has a F3 i beleive, so you can gauge your height to somewhere near his.. also video tape yourself too, that always helps
Old Apr 12, 2006 | 12:56 AM
Reeff's Avatar
Whats up playa pimp
Old Apr 12, 2006 | 01:43 AM
mista_shrpnl's Avatar
mista_shrpnl is an unknown quantity at this point
Originally Posted by Reeff
Whats up playa pimp
no shxt right?...this kid dissapeared
stuntin'_cbr
Nov 20, 2024 11:08 PM
t_ank
Feb 5, 2013 12:00 AM
Jay Rodriguez
Dec 6, 2012 09:27 PM
njstunt855
Dec 5, 2012 04:34 PM
blayl
Dec 3, 2012 02:17 PM
