Hand brake help
Old Feb 16, 2006 | 06:08 AM
Tj929's Avatar
Tj929 is an unknown quantity at this point
Hand brake help
Hi all need a little help with a hand brake, just got my brake shipped to Australia for a 929 from stuntme.com it's a brembo unit with a fixed master , had it mounted on top due to room restictions, could not clutch then get my fingers to the brake, so i swapped it around brake on bottom still having trouble getting my fingers to the brake after clutching. i manage to get 1 finger on it but there is not enough brake it pulls in and touches the rest of my fingers would bleeding more give me more lever? do i need to get the rest of my fingers on to the lever? cause i feel i can't let go of my grip with any more .please advise a struggling aussie Thanks.
Old Feb 16, 2006 | 04:54 PM
SAMBO's Avatar
Re: Hand brake help
I use 2 fingers on my handbrake. And it sounds like you need to bleed the line better.
Old Feb 17, 2006 | 02:42 AM
Tj929's Avatar
Re: Hand brake help
Thanks bleeding the brake tomorrow hopefully i will get a bit more feel.
Old Feb 18, 2006 | 06:02 AM
Tj929's Avatar
Re: Hand brake help
hey guys done the bleeding couldn't get any more feel, it's ok but i still need to pump it a few times, should i cut the lever down so it's short enough so that when i pull it in with 2 fingers it won't hit the rest of my fingers? any suggestions chaeers.
trdtruck26
May 23, 2013 07:56 PM
greenhornet347
Mar 24, 2013 12:22 AM
f4i knight
Feb 26, 2013 03:06 PM
CRFstuntin
Jan 7, 2013 10:06 AM
OneWheelRegulator
Dec 2, 2012 01:25 AM
