f4i fuel pump problem
I bought an 01 f4i that was a little beat up when i bought it. i took the tank off and a couple stunt parts and painted them. the bike ran fine before i took the parts off. i put the tank and stuff back on and it will turn over but wont start. i filled the tank half way up just incase i have to take it off again so it has gas. the fuel pump is plugged in and so are both lines leading to the tank. i get no responce from fuel pump when i turn key. could it be the relays or the fuel pump itself? any body had this happen to them and if so how did you fix it?
Re: f4i fuel pump problem
pm sent! i'd guess a fuse is blown
alright heres an update. took fuel pump off and everything looks fine with wires. i put a volt meter where it connects to the harness and got voltage. then five minutes later i did the same thing and got no power to the fuel pump. the ****?
and ill give that relay trick a shot. the relay looks just fine though but ill swap em out. i just have no power getting to the fuel pump
alright heres an update for anyone still reading. i soldered wire back into ecu, bypassed whole harness with beardos technique. and got nothing. fuel pump relays dont click and fuel pump doesnt prime at all. i called honda and they said they there is no test for an ecu. i put ether in vents to try and catch spark and get it to fire for atleast a second, i got nothing. i take it that means no spark. any body else got any other ideas? im all out of things to try other than buy a new ecu just to see what happens
are the injectors getting power fuel pump prime? do they sound weak? might be the regulator, best bet is put a new fuel pump in it, the f4is fuel pumps are **** everyone i know that has this problem always ends up to be the fuel pump. buddy just had this prob and after all the bs of injectors new rod fuses put a new pump in an brapp running great again.
Did you plug it into the right connecter? My boy in Florida did that. U have to plug into the connector on the short wire on the harness next to were the ground is bolted to the frame.
Back track from the fuel pump to see where u are losing your power using your volt meter, also I have an ecu,tanks/pump,injectors,and a harness as well as other f4i parts if u need something just holler, i may be able to email u a copy of the wires schematic also if u need it.
Make sure the wires contacted to the fuel pump are in good condition, check that wire back to the harness, and make sure their is gas in the tank, i had to hit the throttle 3times then try to turn it on, can you hear your throttle body purge? Post pics if you can, I just went trough this issue with the fuel pump gasket leaking...
All pink wire? Or pink with stripes? The pink wire goes from the ecu to the ignition which could be your problem.....can u see what color wires go into the back of the relay? The schematic I'm looking at has a fuel cutoff relay with br/bl, w/bl, bl, and brwn. Are all your safety sensors good? (bank angle,side stand,clutch,ect.)
