Bent frame & blown engine
Old Apr 12, 2007 | 07:05 PM
Double r -D-'s Avatar
Double r -D- is an unknown quantity at this point
Last time out at the spot I blew the engine & bent my frame in the same day .Has anyone ever had a bike take a hard enough hit to break internal parts in the engine?I'm not sure what broke in the engine yet but it's locked up tight.I've got another engine but not sure if I should try to use the bent frame.Powers cage held up like a champ though
Old Apr 12, 2007 | 07:12 PM
onewheelneil's Avatar
onewheelneil is an unknown quantity at this point
Re: Bent frame & blown engine
that fukin sux.WTF you gonna do now
Old Apr 12, 2007 | 07:21 PM
CapitlCityStunt's Avatar
CapitlCityStunt is an unknown quantity at this point
damn you must have took a good spill
homeboy here in raleigh has a spare 600rr engine off '04 i think. ill see if he wants to part with it if yours turns out to be way bad
Old Apr 12, 2007 | 07:29 PM
Thank's bro,I'm good on the engine,got a spare.Might need a frame though,I think I can still run the same frame but it's about 1/16 from the head so another bad hit on right side is what I'm worried about.
Old Apr 12, 2007 | 09:07 PM
Andreas's Avatar
Andreas is an unknown quantity at this point
What can you expect from honda?
/Andreas.
Old Apr 12, 2007 | 09:08 PM
VK_Boomer's Avatar
VK_Boomer is an unknown quantity at this point
i've seen clutch basket break and lock engine after a hard hit. u may want to start there. good luck though.
Old Apr 12, 2007 | 11:22 PM
Guru's Avatar
Guru is a decent person
/Andreas.
a hit like that on a yamaha the bike would of just dissapeared!!
Old Apr 12, 2007 | 11:39 PM
burn
Old Apr 13, 2007 | 01:01 AM
Scott-'s Avatar
How The **** Did The Frame Get Bent And The Cage Held Up Fine I Dont Understand That. That Bend Is Right Above The Front Mounting Point Of The Cage If The Cage Held Up Fine That Shouldnt Have Happend
Old Apr 13, 2007 | 01:17 AM
s0nofg0d's Avatar
s0nofg0d is an unknown quantity at this point
i was wondering same but i dont know ****
Old Apr 13, 2007 | 03:28 AM
FiSh's Avatar
Give me the wheelie gypsy
FiSh is a decent person
did you hydro lock the engine?
Old Apr 13, 2007 | 03:32 AM
The cage is bent but it's still good to go,motor mount bolt came out no problem to.
Old Apr 13, 2007 | 03:40 AM
REVLIMIT's Avatar
REVLIMIT is an unknown quantity at this point
Ouch...I've heard about Powers cage doing that ****...where the cage holds up really well...but the frame gets fucked up.
Old Apr 13, 2007 | 03:53 AM
babyJOKER's Avatar
babyJOKER is an unknown quantity at this point
they dont make the frame that tough anymore 600rr, 03 636 and up, 04 gixxer and up and the new R6 cuz they focus on making the frame lighther. so that equal to weaker and more fragile frame, one really hard hit could just fucked up the frame. i dont know just my and
Not sure what happened yet.It ran fine for about 30min after that spill then started to knock and locked up in one pass around the lot.
Old Apr 13, 2007 | 04:08 AM
Any opinions on what to do with the frame,rock the streets,keep it in the lot or trash it?I was thinking it would still be good for the streets where I don't crash as much(not crashing is not an option ) and get another solid frame for the lot
oscar600
Apr 25, 2015 08:44 AM
Twag1992
Feb 20, 2013 05:49 PM
iRiEsTuNtAh!
Jan 20, 2013 10:35 PM
blayl
Nov 28, 2012 12:18 AM
painedogg25
Nov 26, 2012 12:12 PM
