flywheel and timing question
The flywheel only goes on one way do to the notch in the flywheel, right? So theres only one way to take it off and one way to put it back on?
Thanks,
JQ
Thanks,
JQ
Re: flywheel and timing question
be carefull when you put it on not to damage the woodruff key
you could damage it and it will shear and you will be dione for the day cause of a 2 dollar part wont hurt anything if it does shear just wont turn the flywheel in the right time anymore
