What Problems can I expect?
Old Apr 25, 2004 | 11:45 AM
flappy188's Avatar
flappy188 is an unknown quantity at this point
I just did the High Volume Oil pump, and i didnt drill out the hole as straight as possable, i think i kinda angled it abit. I know i didnt drill into the case tho. Am i going to expierence any problems now? Thanks, and wish me luck
-Rich
Old Apr 25, 2004 | 01:57 PM
RYANCRF50's Avatar
RYANCRF50 is an unknown quantity at this point
Re: What Problems can I expect?
I drilled mine the same way, because I couldn't get the drill lined up perfect with the stud there. I've had no problems! :YEAH
Old Apr 25, 2004 | 03:49 PM
flappy188's Avatar
Also My trailBikes 88 kit doesnt feel as fast as it should, It almost doesnt feel like its much faster then it was stock, Could the cartb be effecting it? I havent dialed it in yet! also i havent really took it past quarter throttle, how long should i break it in for?
Thanks
-Rich
Old Apr 25, 2004 | 03:53 PM
potential's Avatar
potential is a decent person
you souldn't have any problems w/ yours, but the correct way to do it is to take the one open ended 10mm nut and a closed ended 10mm nut, put them on the long stud (the one that's in the way), lock them together, then use the open ended nut to unscrew the stud, then drill and reinstall. here's a pic from when i did mine (https://www.stuntlife.com/forums/att...chmentid=61229), you can see the threads where the stud screws into the block.
B
Old Apr 26, 2004 | 03:28 PM
MITTER's Avatar
MITTER is an unknown quantity at this point
What size drill bit do you use?
Old Apr 26, 2004 | 04:08 PM
flappy188's Avatar
2mm......................
Old Apr 29, 2004 | 01:32 AM
dingo's Avatar
dingo is an unknown quantity at this point
wanna little hint about breakin?
*(see * below),run the **** out of it.... the rings will seal better, and it will run stronger. no if's and's or but's about it... compression inside the cylinder makes the piston rings seat and seal. the more pressure you put behind the rings making them seal, the better they will seat. all pussing it around waiting for it to break in will do is wear the crosshatch out of the cylinder, and keeps the rings from seating 100%, once the crosshatch is worn, breakin time is used up.
*- before you run the **** out of it, make sure its warmed up to operating temperature. the only thing "break-in" really is, is the piston rings seating and sealing themselves into the cylinder, if you thrash it with a cold engine, you could seize it, then yer fuct.
Old Apr 29, 2004 | 03:06 PM
ZYIFIDDY's Avatar
ZYIFIDDY is an unknown quantity at this point
i used to know a guy who lived by that
philosophy of thrash the **** out of it on break in
his **** ran great for a couple of races then usually blew up
the way ive done it for 30 years
let it idle till warmed up to op temp ride for 15 minutes turn off let cool to room temp ,repeat, change oil check for materials(metals) warm up and ripp it
works for 2 strokes and 4 strokes
main thing is let it warm up like dingo said or you will have probs later on
Old Apr 30, 2004 | 12:43 PM
Jimbo7's Avatar
When I had my YSR rebuilt by Calamari, they had a long paper on how to break it in properly. If I can remember right it was like: warm up engine, ride 5 min. with varied speed, let cool, warm up then ride for 10 min. varied speed.......then do the same for 20 and 30 min. After breaking it in like it said, i raced it that weekend and a month later and it runs flawlessly. Did the same when I put in my 88cc kit. with same results.
Old Apr 30, 2004 | 12:56 PM
Z50NATIONALS's Avatar
you can always tell the g
guy that thrashes his **** for break in
hes usually the one who is broke down at the races
lol
after the forst moto
lol
bowflexmaverick
Oct 2, 2015 02:16 PM
dippah
Aug 9, 2015 02:44 PM
alex71783
Aug 9, 2015 02:18 PM
Duke_Montes
Jul 23, 2015 11:12 PM
