Another Problem!
Old Feb 8, 2004 | 06:28 PM
NickIF's Avatar
Another Problem!
hah, I'm gonna have a break down. I think I finally got the forks fixed... went to take it for a test ride and tried to kick it over and there is zero compression. I actually busted my shin when I kicked it. I mean you can push it down with your hand. It does spring back up, and if you try and kick it over in gear the back tire still spins so I don't think it's the gear. Anyone have any idea's before I have the case split open?
Old Feb 8, 2004 | 06:53 PM
sandmrider's Avatar
Re: Another Problem!
Is the spark plug screwed in? Thats all i can think of.
Old Feb 8, 2004 | 07:18 PM
potential's Avatar
potential is a decent person
wait, what exactly did you do to you're bike between the time it ran and when you found out it won't? in these types of circumstances its almost always human error and it always ends up being something so simple, just gotta think about what you did to it recently. just the other day we couldn't figure out why imprezawd's fiddy was buring oil and building up a ton of pressure in the case, just to find out when he moved his lock cyl. to the back of the frame he pinched the case breather hose!
B
Old Feb 8, 2004 | 07:28 PM
crowdlg's Avatar
crowdlg is an unknown quantity at this point
you would never need to split the cases for a no compression problem anyway.hey keep it simple.dont go out of your mind.start from the plug ad work into the head.is the plug there?if so take it out put your fnger in the hold.kick it with the other hand(on/off switch off or the spark hurts)or get help.do you feel air.is the piston even moving.if the clutch is slipping it wont turn over the motor.the clutch works between the kick shaft and crank.did the cam chain jump time.is it so flooded that the rings have lost there seal to the cylinder walls.
Old Feb 8, 2004 | 09:19 PM
Xidium's Avatar
Check the plug and head bolts.
Old Feb 8, 2004 | 09:24 PM
Silver Surfer's Avatar
I think its the clutch. My friend will fix it for Nick....
and I'm gonna run da beeoootchh on the dyno while its there to see how much HP he is making.
Old Feb 8, 2004 | 09:30 PM
NickIF's Avatar
The bike is at silver surfers, I didn't do anything to it between now and the last time it ran. Hopefully it's something stupid and will be figured out tomorrow
Old Feb 8, 2004 | 10:07 PM
SickFitty's Avatar
SickFitty is an unknown quantity at this point
hey did you install a manual clutch ? if so hit me up I just went threw the same thing...
Old Feb 8, 2004 | 10:39 PM
NickIF's Avatar
nope, stock tranny
Old Feb 9, 2004 | 08:24 PM
NickIF's Avatar
she's getting looked at tonight, I'll be back later with the results. Hopefully it's something stupid!
--*CBR*KING*--
Apr 5, 2022 11:42 AM
bowflexmaverick
Oct 2, 2015 02:16 PM
alex71783
Aug 9, 2015 02:18 PM
Duke_Montes
Jul 23, 2015 11:12 PM
