throttle cable help....!!!!!
Old Nov 24, 2003 | 08:22 AM
bigwhiteboy's Avatar
CEO of o2w
bigwhiteboy is an unknown quantity at this point
Thumbs up throttle cable help....!!!!!
Ok got the 88cc takegawa s stage! the install went perfect except for the throtttle cable..I have BBR bars on the bike so I already have a longer cable...the internals are too short..so I used the cable supplied with the kit... the internals are too short to fit into the twist throttle housing..do I have to modify my twist throttle? anybody else had this issue and what did you do to fix it?
Old Nov 24, 2003 | 12:09 PM
kxrider's Avatar
my buddys does that, he jus ridin with a messd up throttle he got the same kit and everything i wanna know how to fiz that
Old Nov 25, 2003 | 01:28 AM
Jimbo7's Avatar
I think everyone has this problem with the big bore kit and aftermarket bars, I did. If I can remember correctly, the only thing i could figure out to fix it till I got a longer calbe was to play with cap and stuff on top of the carb. Try taking the rubber cover thing off the cap or make sure the end of the cable is hitting the top of the cap as far as it'll go. You'll have to play around with it a while.
With my new longer cable and 18mm carb., it still doesn't quite work. Cus if you turn all the way to the left it'll pull the cable and rev up because the cable cant make a good bend with it hittin the tank.
Hope this helps
Old Nov 25, 2003 | 01:31 AM
HB wetland mxer's Avatar
HB wetland mxer is an unknown quantity at this point
ALL KITS HAVE THIS PROBLEM. I posted earlier about this, and finally got in contact with Two Brothers Racing today. Luckily for me there only 20mins away, becuase yes, YOU DO NEED A NEW CABLE. The make a long cable and special throttle for it which I did have to purchase. While I was there, I must admit they did have EXCELLENT service, and if you ever need a part for your 50, this is where to get it, they have EVERYTHING. ANyways, good luck!
Old Nov 25, 2003 | 08:30 AM
CEO of o2w
thanks guys..got a cable on the way...
Old Nov 25, 2003 | 10:18 AM
cut the sheething off the cable for however much more cable u need to get down into the carb. ive done this about 6 times already with different bikes ive done. just put the cable in a vise and use a air powered cut off wheel to slice it. be very carefull not to hit the cable in the center. then cut that crap off with some side cuts. it aint easy, but thats how ive done em.
Apr 5, 2017 10:29 AM
stuntin'_cbr
Sep 4, 2013 09:20 PM
jmoney2001
Jun 16, 2013 03:38 AM
Kerns BBO
Apr 29, 2013 12:34 PM
