Street Tires?
Old Sep 27, 2003 | 03:21 AM
nitty917 is an unknown quantity at this point
Street Tires?
How hard are they to put on?
Old Sep 27, 2003 | 11:47 AM
J.P.'s Avatar
J.P. is an unknown quantity at this point
I have always used tire irons, it takes a little work but you will get it done. I once tried to use miniture crow bars but it would keep pinching the tube.
Old Sep 28, 2003 | 07:24 PM
BrokenHeadlight's Avatar
BrokenHeadlight is an unknown quantity at this point
tube in street bike tire???
just make sure to use a soapy mix around the bead it helps the tire pop on easier. Former Tires Plus employee...
-Jay
Old Sep 29, 2003 | 04:08 PM
XR STUNNA's Avatar
XR STUNNA is an unknown quantity at this point
Also let the tire sit in the sun for awhile to soften it up. Anything helps those things are a bitch!
Old Sep 29, 2003 | 07:11 PM
stuntboy79's Avatar
stuntboy79 is an unknown quantity at this point
silicone spray and tire irons easy as pie!!!!!
Old Sep 30, 2003 | 04:19 PM
tech126's Avatar
tech126 is an unknown quantity at this point
where can you get them and how much do they run????
Old Sep 30, 2003 | 07:19 PM
stuntboy79's Avatar
Thumbs up
kgmotorcycletires.com or stuntlife.com the bridgestone hoops work pretty good i use 2.75x10 front and rear but you could probably fit a 3.25x10 on the rear
moe_636
Mar 26, 2013 12:22 PM
tomzx6
Feb 18, 2013 02:02 PM
JerZey
Nov 12, 2012 12:06 PM
CRAZY DAN
Apr 1, 2003 07:21 PM
