red barron fork extenders with disk brake
Old Aug 28, 2010 | 06:13 AM
cbrkid's Avatar
cbrkid is a decent person
ok well im new at this review ****. couldnt fine one on this kit so i figured id post one.
heres the kit
http://www.redbaronracing.net/produc...%20Brake%20Kit
when i got it the packaging was busted open so i figured it just got tossed around. dug into it and seemed like evrything was there. there were no instructions included. so i got around to instaling it. and well after i got the fork legs on i fitted the adapter in the brake drum. after i punched out the old bearing i realized it fits with alot of slop. some play before it stops. so i mounted up the front wheel, only to notice the screws that hold on the disk hit the fork leg. had to rig a spacer to make that work. ran into even more issues when i went to mount the brake caliper. the back of the caliper was hitting the disk so i had to put even more spacers and some to move the caliper out because it was also pressing agains te side of the disk.
this **** was a pain in the *** to install. will post some pictures later. along with a performance review when i finaly ride it
Old Sep 7, 2010 | 02:41 PM
Mo-Physco's Avatar
Mo-Physco is a decent person
Re: red barron fork extenders with disk brake
I would have expected better from the Baron
joeybaila
Nov 9, 2020 05:52 AM
gotafurrybike
Feb 7, 2013 02:27 AM
kawasaki622
Dec 4, 2012 10:31 PM
DhGSXR600
Nov 7, 2012 05:54 PM
unstopablee1
Oct 12, 2012 07:12 PM
