xr 50 215lb rider
xr 50 215lb rider
ok Im trying to work on my wheelie game on my 50 and I wanted to know if there is a stiffer shock or something cause when I ride the bike is bottomed out and its like I'm sitting right on the edge of my seat like right on the tail is there also any longer seats I could order
Re: xr 50 215lb rider
That shock is probably worn out. Buy another stock shock off ebay (there around $25) and switch the BBR spring from the old shock onto it. Your front suspension is already setup so don't worry about it. The rear shock was the only thing that wasn't replaced or rebuilt when I redid the bike.
Doesn't sound right . A shock only absorbs energy . If anything , if the shock itself was bad , the back end would be really bouncy .
A bbr spring is only 60% stiffer than stock . Which really isn't that much . But it would definitely help . Unless you're lying about your weight
well scott sold it to me and he would know what was up with it
