Small amount of play in rear wheel
Old Sep 12, 2007 | 09:56 AM
GiXXStuntr's Avatar
GiXXStuntr is a decent person
When my bikes on a stand, and I grab the rear wheel and try to move it from side to side it has a small amount of play in it. What could that be cause by? Also my back brakes are shot so could it be the rotor moving in the caliper or is it my wheel bearings? BTW its a chinese knock off (Sikk MX XL 125cc)
T.I.A.
Old Sep 12, 2007 | 05:32 PM
GiXXStuntr's Avatar
Re: Small amount of play in rear wheel
anyone?
Old Sep 12, 2007 | 06:08 PM
fastrsho's Avatar
fastrsho is a decent person
probably wheel bearings....
Old Sep 13, 2007 | 09:58 AM
GiXXStuntr's Avatar
How can I tell tho?
Old Sep 17, 2007 | 03:51 PM
GiXXStuntr's Avatar
bump?...
Old Sep 17, 2007 | 04:42 PM
PNOBOI's Avatar
PNOBOI is a decent person
get a honda best advise bro
Old Sep 21, 2007 | 10:39 AM
GiXXStuntr's Avatar
isn there any way to prove a wheel bearing or rule out other problems?
Also is this why I tend to sway to one side during stand ups?
Old Sep 21, 2007 | 12:12 PM
binder929rr's Avatar
back in the saddle again
if you can't tell the difference then there's nothing really we can tell to make you know the difference.
it's either the wheel bearings or the spokes are way loose. take it to a mechanic, he'll walk over and wiggle the rear tire and tell you right away what it is.
Old Sep 22, 2007 | 10:14 AM
GiXXStuntr's Avatar
thanks for the help. Im gunna go with wheel bearing...
Old Sep 22, 2007 | 02:10 PM
[T-Roy]'s Avatar
[T-Roy] is an unknown quantity at this point
wheel bearing
broken/loose spoke(s)
loose axle nut
you just gotta figure it out. we can do much for you on here. check those things. good luck.
Old Sep 22, 2007 | 03:45 PM
Catman's Avatar
T.I.A.
those knock off pit bikes can be a pain. Got one that threw the chain and tore off the stator pickup after 10 min.. From some loose sprockers that fit like **** and a crappy chain.
swampy
Aug 25, 2023 04:35 AM
POCKEE999
Oct 22, 2014 12:00 AM
GT Stunts
Jan 4, 2013 12:57 PM
kawasaki622
Dec 4, 2012 10:31 PM
kawasaki622
Dec 3, 2012 07:00 AM
