Stock engine with 20mm carb
Old May 23, 2003 | 10:42 PM
BigboyonaGIXXER's Avatar
I'm Getting Used to Posting
BigboyonaGIXXER is an unknown quantity at this point
I think I might have made a Bo Bo I bought a 20mm carb set off ebay for $129 but i only have astock motor as of now . My question is can I run this kit with stock engine or do i have to wait for the big bore kit? HELP
Any body out there with this set up?
Old May 24, 2003 | 11:30 AM
50madness's Avatar
50madness is an unknown quantity at this point
You will have to go way down on the size of the main jet. Having a carb that big on a stock motor will probably take alot away from the bottom end.
Old May 30, 2003 | 03:42 AM
atomrotten's Avatar
atomrotten is an unknown quantity at this point
You will have to waite to use it with a big bore. An xr70 carb that is a 16mm is as big as you can go without ruining the performance.
Later Atom RoTTeN
www.sanomx.com
Old May 30, 2003 | 10:35 PM
FIVEO's Avatar
FIVEO is a decent person
Hey ATOM will the 16 carb fit right on a stock fiddy or do you have to get a different intake elbow or whatever it's called???????
Old Jun 1, 2003 | 10:49 AM
birddogg's Avatar
birddogg is an unknown quantity at this point
Thumbs up
Use an ATC70 intake. It will take care or any clearance problems.
tomzx6
Feb 18, 2013 02:02 PM
