xr50 rear peg - cant find them
Old Oct 22, 2006 | 04:37 PM
7808's Avatar
7808 is an unknown quantity at this point
where do you guys get your rear peg for your 50s? doesnt look like a bike one would fit
do they sell them anywhere or do you just re tap a bike one
Old Oct 22, 2006 | 05:09 PM
Crazy D's Avatar
I'M A REGISTERED USER !!
Re: xr50 rear peg - cant find them
http://www.esd-mfg.com/50stunt/stunt_stunt_pegs.htm
Bicycle ones will work , but you might have to drill out the hole to fit thru the axle bolt . Also no chain adjusters on them .
And you might need a longer axle bolt if they are too thick (where the hole is)
Old Oct 22, 2006 | 05:13 PM
7808's Avatar
$54 for a peg ouch
Old Oct 22, 2006 | 05:15 PM
Crazy D's Avatar
You asked
They come in a set .
Old Oct 22, 2006 | 06:21 PM
letsride's Avatar
go to a bmx shop. you can pick up a set for like $25
Old Oct 23, 2006 | 10:00 AM
fakehatch's Avatar
fakehatch is an unknown quantity at this point
I drilled out a bike peg to 1/2 inch (only one, you'll need a extended axle for two) and I kept my chain adjuster. Grip tape that ***** too, trust me.
Old Oct 23, 2006 | 11:12 AM
FREESTYLEKYLE's Avatar
I got mine at walmart for 7 bucks a pair you can only fit one with a stock axel and keep your adjusters, only catch is you have to drill out the peg to fit the axel but the peg works great after some grip tape. you might want to grind a 45 on the edge of the peg to keep it from grabbing the ground while turning.
Old Oct 23, 2006 | 06:03 PM
7808's Avatar
do you have to flip the axle around to have the peg on the left? the threaded end of my axle sticks out the right side
Old Oct 23, 2006 | 07:25 PM
I didn't flip mine, i still have the nut on the right.
you can fit two bike pegs on your stock axel if you remove the tensioners but its kinda hard to line up the wheel and keep it there.
Old Oct 27, 2006 | 01:04 PM
turboglenn's Avatar
i have 2 BMX pegs ona astock axle... took the adjusters off and welded 10mm bolts to teh pegs to fit in the adjuster slots... been working for 2 years with no problems
butif you get BMX pegs,,, cut them shorter or you'll drag tehm adn low side hard in corners and sit down circles
Old Nov 9, 2006 | 07:57 PM
gixxer601's Avatar
gixxer601 is a splendid one to beholdgixxer601 is a splendid one to beholdgixxer601 is a splendid one to beholdgixxer601 is a splendid one to beholdgixxer601 is a splendid one to beholdgixxer601 is a splendid one to beholdgixxer601 is a splendid one to beholdgixxer601 is a splendid one to behold
see all these headaches and labor you have to put into a bmx peg and you end up making it the 50 stunt peg. thats why i went ahead and ordered it from them.
Old Nov 9, 2006 | 08:03 PM
Aaron Colton's Avatar
Aaron Colton is an unknown quantity at this point
Post Re: xr50 rear peg - cant find them
WWW.50STUNT.COm
One stop 50 shop
-Aaron
Old Nov 9, 2006 | 08:08 PM
GundamnitPete's Avatar
Don't read this.
buy a 14mm "oversixe axle" BMX bike peg, notch the side of it with a file or grinder so it will fit on with the adjusters.
done.
Old Nov 11, 2006 | 10:24 AM
moorport's Avatar
moorport is a decent person
Just hit me up, I would have already had the best pegs made on your bike by now!!
www.50stunt.com
They bolt up in a couple minutes!
Old Nov 14, 2006 | 12:21 AM
Stubbz's Avatar
i used a set of bicycle pegs on my 06 ttr 50 as well, i had someone CNC cut them to fit around the chain adjusters and sit tight to the swingarm, works great
Old Nov 14, 2006 | 12:39 AM
turboglenn's Avatar
if you're like me and have more time and skill than spare money it's really not that bad/hard to do... i just pulled the adjusters...slapped it all together...then held the 10mm bolts in place and tacked tehm on while thee bike was sitting ona bucket... but if you don't have the right tools and thigns like that it's easier to jsut buy them... not to mention the 50stunt pegs have a great knurling on them for awesome grip.... BMX pegs are simple and cheap, but nothing grips like a 50stunt peg
Old Dec 3, 2006 | 09:56 PM
ahenry's Avatar
ahenry is a decent person
dont pay for a damn thing, get you a piece of steel tube piping, Free almost any shop. take off the axle nut and weld it onto it, and you can just screw it on like a nut.
Name:	adams pics1 018.jpg
iRiEsTuNtAh!
Dec 30, 2012 01:34 PM
dans
Dec 4, 2012 09:29 PM
unstopablee1
Oct 12, 2012 07:12 PM
