Help with after market clutch in XR70
I have just installed an after market manual clutch kit in an XR70,
Is it normal to have to leave the clutch handle out when starting the bike,
If you pull the clutch handle it the kick start does not turn the engine.
Have I missed something during the install.
Thanks
Thanks
Re: Help with after market clutch in XR70
that's normal.. you have to start it in neutral. there are 2 types of transmissions sone of them are able to start in gear, but they are not honda tranmissions.. i forget wich ones do start in gear.
it's basicly because the clutch is mounted on the crank so when you pull the clutch you dis-engage the kicker gear from turning the crank
Originally Posted by samkfx400
my 50 starts in gear? and its definitely a honda tranny
ARsixx
Jun 12, 2013 07:30 PM
