help puttin tire on swing arm!
Old Aug 10, 2006 | 08:58 PM
mk_ek9's Avatar
mk_ek9 is an unknown quantity at this point
sup got the street tires for my 50 .. stock size and everything. just lil wider for stunting.. i put them on the rim and everything but the tire dont fit on good.. its hitting the swing arm.. wat can i do 2 fix that.. also if i have 2 change swing arm witch 1 should i do..cuz i dont wanna go 2 long cuz then i wont be able 2 stunt if its 2 long.. let me no asap got the bike in 1000 pieces.. thanx ..:YEAH tire size is 3.5 X 10... guy told me will fit right on!!
Old Aug 11, 2006 | 08:24 PM
pacustoms's Avatar
pacustoms is an unknown quantity at this point
Re: help puttin tire on swing arm!
where you get the street tires at?
Old Aug 11, 2006 | 09:03 PM
ratherbewalking's Avatar
ratherbewalking is an unknown quantity at this point
3.0 is what you want
Old Aug 12, 2006 | 12:29 PM
turboglenn's Avatar
yep, 3.5 needs a long *** chain to work in the rear, and will also keep knocking the rubber boots off your forks. they are too big and just too much trouble to run, plus they're not that great for stunting. the only reason i know is because i mounted 2 sets up about 2 weeks ago for a friend.. they are now back off in favor of some 2.75 x 10 IRC's. they were awfull for circles for some reason and the front one would jam in the fender and throw me over when i stopppied on them
the only setup i've seen them work adn fit welkl on is a friends motard that has BBR SP-5's and a BBR +2 swinger
Old Feb 3, 2007 | 05:26 PM
User Error's Avatar
User Error is a decent person
i'm Running Kenda's and love them... they are cheap... 10x2.5 in the front and a 10x2.75 in the rear and that looks to be about as wide as possable...
Old Feb 8, 2007 | 11:54 PM
project-c2's Avatar
project-c2 is an unknown quantity at this point
I got 90/90 michelin S1's to fit. Got stock swingarm with prowheel rear shock. Had to get a new chain to push the rear tire more back. Other than that, the front sides would touch the dust boot on the forks, so I got Red Baron fork extenders and 2 Bros. springs to match the rear shock. Oh and 2.75 tube in front and 3.00 tube in rear.
Old Feb 8, 2007 | 11:56 PM
project-c2's Avatar
As for the regular style. I used the Kenda 3.00x10 with a 2.75 tube, before the 90/90s
Old Mar 20, 2007 | 12:20 AM
yellow1rider's Avatar
yellow1rider is an unknown quantity at this point
Man I just ordered those tires... I have to get new chain to push tire back on stock set up or can you make it work without the new chain?
Old Mar 20, 2007 | 01:03 AM
letsride's Avatar
try getting your money back or trade the tires for the right size
CBRNY13
Jun 3, 2013 09:50 PM
miamicanes06
May 23, 2013 09:37 PM
Kerns BBO
Apr 29, 2013 12:34 PM
kntmare181
Feb 14, 2013 01:00 AM
speedjunkies
Jan 14, 2013 05:55 PM
