shift pattern
Old Oct 26, 2005 | 10:13 AM
mrdogboy's Avatar
mrdogboy is an unknown quantity at this point
shift pattern
Is there a way to change it from 3 up to 3 down ?
Old Oct 26, 2005 | 12:19 PM
Shawn742's Avatar
Shawn742 is an unknown quantity at this point
Re: shift pattern
Yep, just flip your transmission upside down.
Haha nah I really don't know, maybe add one of those Harley shifter pegs where you can press it down in the back or pull it up in the front.
Old Oct 26, 2005 | 01:51 PM
mrdogboy's Avatar
Re: shift pattern
shawn-
shhhhhhhhhhhhhhhhhhhhhh !
Old Oct 26, 2005 | 02:39 PM
C6matt's Avatar
Lacks self-control
C6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud of
Re: shift pattern
easily? nope
Old Oct 26, 2005 | 02:51 PM
mrdogboy's Avatar
Re: shift pattern
ok ! _____
Old Oct 27, 2005 | 02:28 PM
chaos321's Avatar
chaos321 is an unknown quantity at this point
Re: shift pattern
What is the not so easy way to do it? I have a knock off that is 4 down and would like to switch it to four up. thanks
Old Oct 28, 2005 | 08:59 AM
C6matt's Avatar
Lacks self-control
Re: shift pattern
well the trans out of the older z 50 were 3 down... you would have to pull apart the trans and change to the old style mecanism.. I dont know part numbers, or if they are interchangeable because I've never though of wanting to change them around... hope that helps
Old Oct 28, 2005 | 09:30 AM
NINER's Avatar
Retired
Re: shift pattern
It's not "easy" to do, but this kit should give you an idea of what you need to pull it off:
http://www.dratv.com/shpacokitfor.html
Old Nov 1, 2005 | 11:31 PM
corprin's Avatar
corprin is an unknown quantity at this point
Re: shift pattern
you just need a 3 down gear set with shift forks/drum.
I am currently running a 1-N-2-3-4 in my XR50, and I love the thing. Only took swapping out the parts. The case of the XR50 is the same as 90% of all other 12v 50cc hondas with the same type engine.
Apr 5, 2017 10:29 AM
xia1233
May 19, 2015 04:02 AM
WARstunter
Apr 14, 2014 11:55 PM
Hinks
Feb 19, 2003 02:33 AM
