few pics of rear handbrake...
Re: few pics of rear handbrake...
here ya go...........
http://www.fiddylife.com/forums/showthread.php?t=163
make sure and sand the drums and shoes while you have it apart
Originally Posted by turboglenn
i can't find my cameras memory card, i'll get you pics of the latest setup tomorow hopefully
EDIT here ya go, my g/f had the card...where the cable attches , it's a piece of chome tubing, that i welded toa small rectangle of steel as a riser, and welded teh entire assembly to the brake rod. the brake perch bolts right on the swingarm.
the right cable can be tricky to find. I"m using one that;s labeled "84 yamaha rear hand brake"
Originally Posted by JPratt
has anybody tried a homemade handbrake with the 50stunt extended brake arm?
i wanted to, i just don't have the funds for the arm right now. I bet it would work great.
COol, I might try it once I build mine. You get pics of the new HB setup of yours yet? :YEAH
the current setup is the one in the pic above, brake perch on teh swinger
