motor won't run right unless bike gets warmed up for 10 minutes
Old Jul 3, 2005 | 08:45 PM
truestunna's Avatar
truestunna is an unknown quantity at this point
The pass few months taking out the fifty it's starting to take a while before it's starts to get all it's power, around 10-15 minutes. What would cause this? is this a sign the motor has low compression? Basically i guess what i'm wondering is if i should through in a new motor or is there some adjustments i need to make.
Old Jul 3, 2005 | 09:07 PM
Schwartz's Avatar
Schwartz will become famous soon enough
Re: motor won't run right unless bike gets warmed up for 10 minutes
Could be a few things. If the valves are tight it can cause this. Real easy to adust them on the 50s.
Could be lean. Try raising the needle in the carb 2 spots. This means you need to lower the clip. It will most likely be backfiring until it gets warm if it's lean. More of a Pop.
BlackMarketBike
Jul 9, 2024 03:25 PM
zeus_r6
Apr 2, 2013 04:26 PM
Ethiopian
Feb 8, 2013 11:22 AM
casey f2
Nov 1, 2012 04:12 PM
On1wheeL1000
Oct 22, 2012 11:26 AM
