question?? 82cc bbr kit
Old May 19, 2005 | 10:00 PM
mrluvaluva's Avatar
mrluvaluva is an unknown quantity at this point
Hey now!!
I just got to ride my fifty with the bbr 822cc kit installed . seems to have alot of top end. i have put a filter on it not kn but similar and a d@d exhaust i think thats what it is. any way its alittle boggy. Do i need to jet it. Im running the carb stock. And also im thinking i should run a bbr filter or something else. the filter is one from ebay looks like a replica of k @ n but i think its smaller.
should i drop a tooth in the front sprocket? too
thanks
andy
Old May 19, 2005 | 10:15 PM
rdccarpet's Avatar
rdccarpet is an unknown quantity at this point
Re: question?? 82cc bbr kit
i would drop 1 tooth in the front and try putting your stock air box back on i think the bike runs better with it atleast mine does
Old May 20, 2005 | 03:10 AM
WAX-AZZ is an unknown quantity at this point
is there a 82cc big bore on the market that runs well on the stock carb?
Old May 20, 2005 | 05:40 AM
dont drop a tooth, add a tooth in the front. stock airbox, stock carb with a 62 main jet. done
Old May 20, 2005 | 05:44 AM
mrluvaluva's Avatar
FAB "you the **** Bro"
thanks
Old May 20, 2005 | 10:00 AM
rdccarpet's Avatar
Yea My Bad Add A Tooth
Old May 20, 2005 | 10:11 AM
$!x's Avatar
$!x
$!x is a decent person
If i were you i would just put a bigger main jet on it. What size are you running on it right now? Tell me what you have and i'll try to give you a good size to put on for a 80cc. Close enough to a 82cc bored out kit.
Old May 20, 2005 | 04:38 PM
Z50NATIONALS's Avatar
dig around on ebay and find you a xr70 carb
and intake
i run the d&d with this set up and a 15 tooth countershaft sproket
and a k&n on my stocker and it ripps
with an 82 itll ripp even nicer
if you can find a 70 head or a trx 90 head even better
stock stuff set up like fab works too just a little extra info for ya
blubbering off the bottom is because its lean and on a stock carb you cant change the pilot jet, you can on the 70 carb
Apr 5, 2017 10:29 AM
zeus_r6
Aug 23, 2014 04:11 PM
sbrider23
Jan 27, 2013 04:14 AM
daanek82
Jan 14, 2013 11:38 PM
ducKhunt
Dec 12, 2012 04:44 PM
