hondaminitrail engine upgrade questions
Old Nov 20, 2004 | 03:38 PM
resistive's Avatar
resistive is an unknown quantity at this point
I have an 88 kit on one fiddy and can never get the thing tuned right. I have another stock fiddy and it always runs sweet. I was thinking of switching the 88 out for a 110 engine from Classic Honda (www.hondaminitrail.com). It apparently has 6.5HP, but i don't know how much more that is than stock . ..
anyone have any experience with the Hondaminitrail 110 (with 4spd manual clutch) or 100 (3 spee auto clutch) engine upgrades?
anyone know how many HP a stock fiddy puts out?
cheers, rob
Old Nov 20, 2004 | 03:43 PM
Re: hondaminitrail engine upgrade questions
stock honda is 2.5 or 3hp
Old Nov 20, 2004 | 03:45 PM
whats makes u think the 110 will be any easier to tune?
Old Nov 20, 2004 | 03:59 PM
resistive's Avatar
i'm hoping a stock motor (stock 110) won't be as tempromental as a tricked out 50 (bored to 88)
Old Nov 20, 2004 | 04:23 PM
if you cant tune it, why not just take it to somebody who knows what theyre doing. be cheaper. not really that hard to do either, the bike will tell you what to do
Old Nov 20, 2004 | 05:00 PM
resistive's Avatar
i can tune it, but if i tune it at home (sea level) it doesn't work at the skifields where i race DH MTB, and vice versa.
my stocker runs so sweet I'm thinking a stock Honda 110 with a 4spd manual cluth should run sweet for years and years
anyone have experience with the 110s listed on hondaminitrail.com?
... or the 100s?
Old Nov 20, 2004 | 06:54 PM
then a stock motor wouldnt be any different. the laws of physics still apply to a stock motor. higher altitudes require leaner jetting, so get it running slightly on the lean side, should be a happy medium.
btw, it wont be a stock honda anything, stock honda is 50cc. i think those are chinese motors theyre sellin or dai ichi or whatever. learn to tune what you got is the best option
Old Nov 20, 2004 | 07:00 PM
if you want stock honda, put xr70 cylinder,head,carb,airbox on it
Old Nov 20, 2004 | 07:54 PM
C6matt's Avatar
Lacks self-control
C6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud ofC6matt has much to be proud of
I was thinking about doing that, any one know what they'll run at the dealer?
Old Nov 20, 2004 | 08:02 PM
arm and a leg
watch ebay or check ronayers.com
Old Nov 20, 2004 | 09:34 PM
could this be said any better?? great advice brotha. :YEAH
Old Nov 21, 2004 | 09:00 AM
resistive's Avatar
good advice for sure... and based on it I need to ask a different set of questions ...
Mt 88 big bore with 18mm carb is really tempromental. My stock fiddy starts first kick and runs clean every time, every place.
I had a fiddy mechanic look at my 88 and he changed the jet, but after a few hours of running its running like crap in the midrange. I'd been told that bored out 50s could be a real hassel to tune, and that I might never be able to get it running spot on ... that's where I started looking at larger "stock" motors...
The 110cc "stock" motor with 4sp manual cluth sounds good, but if its a cheap piece of Chinese crap that's going to break down, then that's no good ...
I love my stock fiddy and will always keep that stock, but i want my second fiddy to be all bling, nice and fast AND as reliable as hell.
Can a better carb with more adjustments help to keep the thing in tune? Any other suggestions for the 88 to make it run better?
and, What do you think my best motor and gearbox option is for a fast fiddy?
Old Nov 21, 2004 | 09:45 AM
sounds to me like yer "honda mechanic" fed you with some bullshit because he couldnt figure out how to get it running right. i can assure you that an 88cc with an 18mm carb and 85 main jet WILL run flawless and be just as reliable as a stock 50. before even screwing with the carb, i would check to make sure a few things are correct...
1. cam timing. flywheel on "T" and cam sprocket "O" lined up EXACTLY with the notch in the head.
2. ground wire. make sure the ground that was removed to take offf stock filter is CLEAN and TIGHT.
now that both those things are checked and double checked you can go onto playing with the carb.
a 110 is nothing more than a stroked 88 so i dont understand how anyone can tell you it will be easier to tune. and the carbs that come with those chinese motors belong on a lawnmower, so finding jets and tuning will be a real hassle.
dont spend any money. the 88 you have will be fine once its tuned up. i know it can be a hassle but just take yer time and read before you start playing with things you dont understand. these minor things will far outweigh all the bullshit you will be dealing with after you purchase a 110. now git-r-done.
Old Nov 21, 2004 | 10:24 AM
after you do what he said, read this
http://www.motocross.com/motoprof/mo...1/carb101.html
that pretty much sums it up and should help you understand the carburetor. go buy a couple new plugs, that will make diagnosing it much easier. the plug will tell you whats going on
Old Nov 21, 2004 | 10:55 AM
wow. nice link. dont get much easier than that
Old Nov 21, 2004 | 07:32 PM
ricerocket1135's Avatar
ricerocket1135 is an unknown quantity at this point
stock is roughly 2.5 at the shaft... so probably closer to 2 at the rear wheel....
Old Nov 29, 2004 | 07:20 PM
Z50NATIONALS's Avatar
print that out and take it to the honda guy
he needs it
that is some good advice on there nice post hurricane
i have a stroker motor starts on the first kick everytime
fab is telling you right get it dialed in
zeus_r6
Aug 23, 2014 04:11 PM
cagivos
Nov 23, 2013 01:49 PM
junior07
Feb 24, 2013 02:48 PM
junior07
Feb 24, 2013 02:21 PM
JerZey
Nov 12, 2012 12:06 PM
