low speed wheelies...
Old Aug 5, 2008 | 07:46 PM
xdeadboox's Avatar
xdeadboox is a decent person
got 2nd gear and balance point down on the a fiddy finally after a solid 2 days at it. been screwin around with sit down off idle low speed wheelies, and am having a problem with my side balance sometimes. i find that when i launch it up to BP off idle, and spread my knees wide, then adjust them by pullin one knee in to go the opposite way it helps a lil. is this the right way of balancin side2side? how are you guys rippin turns at BP and controlling side 2 side movement. any advice appreciated. thanks
btw its a bone stock '97 z50 with the fatty 8 inch rims/stock tires 10psi rear...
Old Aug 5, 2008 | 08:11 PM
NHRR-RIDER is a decent person
Re: low speed wheelies...
i ride a 06 crf 50 and i use my knees sometimes but if i understood you right your trying to turn at bp? then i only use my inside leg and alot more upper body weight shifting. nd i use alot more rb nd throttle control. i hope this helps im not really sure i understood what your saying
Old Aug 5, 2008 | 08:20 PM
xdeadboox's Avatar
kinda askin 2 questions... how to keep side to side balance, and if i'm right by just usin my knees like i am when in a straight path. i know it defianately helps a lil. but also how to turn and keep from just falling into the circle. i can get 180deg, but then i just keel over like a dead dog. i get what your sayin about more throttle and rear brake when turning and using upper body more, i guess i just have to get more seat time...
and i know i type like a fuggin retard hahaha
Old Aug 5, 2008 | 08:29 PM
FREESTYLEKYLE's Avatar
I use my knees a little.... but slide my butt side to side on the seat (opposite the way you want to go) or just turn the wheel (unless doing circles) in the direction you want to straighten out to. a big part is also starting the wheelie straight from the beginning (2 nd gear has speed to help straighten you out if you dont come up perfect) make sure when you first pull it up you learn to pull evenly and start the wheelie as straight as possible, its a lot easier to keep it in line than get it there.
Old Aug 5, 2008 | 08:51 PM
xdeadboox's Avatar
thats where i got today... i found if i keep my knees a lil wide, that i can pull it up straight at real low speed more consistantly. i'm gonna give that *** slide a whirl tonite. thanks for the advice guys.
Old Aug 5, 2008 | 09:42 PM
the *** slide works good for big corections for small ones try turning the bars, turn them slowly the way you want to go then slowly straighten them as you get in line. when you get it, it will be like second nature you won't have to think about it you'll just do it as needed inbetween some sick *** combos.....
Old Aug 5, 2008 | 09:47 PM
whatever works for you, but make sure after you get it up you bring those knees in.......
aarona64
Nov 3, 2014 04:13 AM
DriftyStuff
Oct 4, 2014 10:59 PM
nver enf
Apr 11, 2014 09:44 AM
RL3000
Feb 21, 2014 04:47 PM
Ls1Mx5
Feb 6, 2014 10:44 AM
