50 engine help
Old Jul 18, 2007 | 09:24 PM
Roadcrayon is an unknown quantity at this point
50 engine help
so i finally put a new tube in the 50 and i hadnt rode it in months, i take it out screw around for a bit then after about 5 min i notice a sputter at high rpm. is it just a simple highspeed needle adjustment on the carb i need to do or could it be more serious.
Old Jul 19, 2007 | 04:32 AM
50slut's Avatar
"Keep Your F4i's IDIOTS"
Re: 50 engine help
NO! NO! NO! just run the **** outta it for a bit, it will heal itself! DUH! its a honda!
Old Jul 19, 2007 | 10:37 AM
cullins's Avatar
cullins is an unknown quantity at this point
Re: 50 engine help
might just be old gas.
Old Jul 20, 2007 | 12:56 AM
Mr. Hooligan's Avatar
Re: 50 engine help
They act odd some days just beat on it and it will fix itself....
Old Jul 20, 2007 | 01:02 AM
50Outlaw's Avatar
da fiddy bitches!!!
Re: 50 engine help
i havethe same problem with mine every once and awhile.. turned out to be the 2 wires going into the coil.. try pushin those on there good and crimpin em with needle nose pliers...
Old Jul 30, 2007 | 01:10 PM
reynolds_brad's Avatar
50 NUT
Re: 50 engine help
check your ground, make sure its on their good and has a clean contact.
Old Jul 30, 2007 | 07:55 PM
turboglenn's Avatar
Re: 50 engine help
yea, check the wiring to teh coil and the ground ( hell check all teh wire connections for water or corrosion), put a new plug in it and maybe some fresh gas... one of thos e should take care of it
Apr 5, 2017 10:29 AM
JFLACO610
Jul 25, 2013 06:27 PM
stuntin'_cbr
Feb 12, 2013 06:46 PM
blayl
Nov 28, 2012 12:18 AM
