What in the MOTHERF*CK is the solution
Old Nov 9, 2004 | 11:47 PM
Fuscat's Avatar
Re: What in the MOTHERF*CK is the solution
dig it, I'll give it a whirl...
thanks for the tips all. pisses me off I gotta get this under control..
Old Nov 9, 2004 | 11:56 PM
50man's Avatar
50man is an unknown quantity at this point
sounds like you don't have enough pressure for weight to me. If you had too much pressure it would explode, not be flat the next day. Also are you runnin the heavy duty tubes?
Old Nov 9, 2004 | 11:58 PM
Kev900RR's Avatar
Buy a h/d tube and two full size mx tire spoons, Use lots of windex when putting the tire back on. Do you take the tire all the way off the rim when changing a tube? Or are you one of those guys that spend three hours trying to put the stem in blind?
Old Nov 10, 2004 | 12:19 AM
suzukirider03's Avatar
suzukirider03 is an unknown quantity at this point
hey derek.. im runnin like 19-20 psi in mine..and i have no problems.. im still on my stock tube.. only patched it once..
Old Nov 10, 2004 | 08:49 AM
Fuscat's Avatar
i dunno about heavy duty tube?! The dealer sells me an IRC tube? I just ask for the 2.5/2.75x10 tube, don't remember any H/D on it anywhere..? Damn pressure is a confusing subject some people say im running not enough others say too much..?
Kev, I don't take the tire all the way off just one side.. It only takes me about 30 seconds to get the valvestem back in though?
Old Nov 10, 2004 | 02:59 PM
five0addict's Avatar
five0addict can only hope to improve
dont tighten the bolt on the valve stem, you may need to get a rimlock.
or try putting a few dabs of superglue on the bead before you fill it up with air
Old Nov 10, 2004 | 03:05 PM
Fuscat's Avatar
im going to take it all off and apart again tonight and see what the deal is.. I got a new tube on my lunch today. patches never seem to hold for me. must be too fat lol. i could have paid for half of a billet wheel by now at the price of all the tubes iv popped..
naturally the box the tube comes in does not make any mention of proper air pressure level. do I go by whats on the side of the tire itself then?
Old Nov 10, 2004 | 03:17 PM
yes, go by what the tire tells you. skuff up the area around the patch, apply the glue to the hole, let it cure for a couple minutes, set the patch, put some glue around the outside edge so it seals. let it dry for 30mins in the sun before you re use it.
Old Nov 10, 2004 | 04:28 PM
Z50NATIONALS's Avatar
moose makes a tire core for the baja stuff and enduro stuff i dont know if they offer it for that small of tire i guess you could cut it down
you might try that or malcolm smith
Old Nov 10, 2004 | 04:53 PM
Fuscat's Avatar
Is this what your talking about Z?
http://www.motorcycle-superstore.com...674&division=6
not finding anything else by Moose or Malcolm Smith Products..
hugomferreira
Jun 14, 2013 10:31 AM
J-Hook
Outermost
Feb 3, 2004 10:11 PM
Pornstar
Dec 27, 2003 08:13 PM
Lucky~13
Nov 21, 2003 09:41 PM
