New tire not holding air...
i got 2 new pirelli 3.00-10 tires and irc tubes and installed the front tire perfectly...
But when i got the back tire on the rim and pumped it, the air just came right back out???
i dont think i pinched the tubes so is there any other things i might have forgoten to do???
Re: New tire not holding air...
I pinched 1 tube twice in a row and had to patch the dam thing over and over
U said "U don't think u pinched it" Well take the tube out pump it up and check for leaks.....use soapy water this will help.
If there really isn't a leak I have no idea what else the problem could be other then the valve steam is fukt cuz is the tube keeps deflating.....then there is obviously a leak some where.
ight thanks guys ur probably right ill go get another tube and have someone install it cause i dont have any more money if i pop that one too... THANKS!!!
nsschwenk
Oct 16, 2012 06:34 PM
