how much oil do I put in
Re: how much oil do I put in
It's .6 quarts .
Warm it up .
Shut it off .
Drain the oil . Hold the bike upright and level cause the plug is on the right side .
Put the drain plug back in (tighten to 18 ft. lbs.
Fill with .6 quarts .
Warm it up again .
Shut it off , and let the bike sit a couple of minutes .
With the bike in the upright position , recheck the dipstick and fill (if needed) to the upper fill mark on the stick .
Warm it up .
Shut it off .
)Fill with .6 quarts .
Warm it up again .
My arm is a calibrated torque wrench
anyway... just start with 1/2 a quart, start it for a few seconds to let it circulate, then re-check and add oil as needed. To ceck it pull the dipstick.. clean it off, then just set it in the hole ( don't screw it in) and then pull it out and read it...add opr remove oil till it's right. There's no magic amount of oil that is going to work everytime because there's too many factors like adding an oil cooler or not getting all the old oil out befor adding new oil. so unless you just want to over fill it you're going to have to read the dipstick instead of just dumping in X amount of oil because that's what johny or dave puts in his
greenhornet347
Oct 15, 2012 02:26 PM
