Need some help guys!!!!!!!!!
Old Apr 10, 2007 | 02:31 PM
Jivecoolie's Avatar
Jivecoolie is a decent person
I was doing some trail riding, was in 3rd gear and I went to down shift to 2nd but I hit a bump and accidently went down to 1st so the engine rev'd pretty high. Then all of a sudden when I tried to get on the gas the bike just quit. Started it back up and it did the same thing. Only way I was able to make it back was to turn the choke on halfway, the bike would run but still tried to turn off if you gave it to much gas. Can anyone point me in the right direction of where to start at? The engine is stock other than a k&n airfilter and a breather kit.
Old Apr 10, 2007 | 02:35 PM
Righteous 1's Avatar
Re: Need some help guys!!!!!!!!!
Check your spark plug, see how it looks...
Old Apr 10, 2007 | 03:07 PM
Jivecoolie's Avatar
Plug looks ok. I checked the fuel line to make sure it wasnt clogged or anything, it was ok. I started it up again and like I said with the choke fully on it will rev like its supoose to, and with the choke off it quits.
Old Apr 10, 2007 | 05:11 PM
y2kmk's Avatar
y2kmk is an unknown quantity at this point
righteous = thats a sick bubbler!
OP - open up your carb and check it out on the inside. clean the needle and seat out. also clean the jets.
what kind of carb is it? what kind of bike? when i got my 125 the stock carb did the same thing, i threw a mikuni on there and never worried about it again.
Old Apr 10, 2007 | 05:22 PM
Jivecoolie's Avatar
Its a 2000 xr50 with the stock carb.
Old May 10, 2007 | 02:57 PM
Z50NATIONALS's Avatar
pull the float bowl and clean the jets you probably sucked something into a jet
if you have to turn the choke on it is running lean
OneNaked636
Jan 12, 2013 12:31 PM
SicK06RR
Dec 27, 2012 12:03 PM
Jeffknight27
Dec 3, 2012 10:55 PM
Jrose152
Nov 4, 2012 09:17 PM
