stunt parts?
stunt parts?
i have an X1 pocket bike and im tired of just ridin around so i was thinkin of puting like bmx pegs on it. i was wonderin if this is all i can do or is there a magical site out there all about stuntin pocket bikes that sells 12 bars and stuff like that.
Re: stunt parts?
stunt parts are hard to find for pocketbikes we had to make them but the x1 is not a pocketbike its a middy its alot bigger then my bikes ive seen people stunt the x1 but ive never seen them with 12 bars im sure it been done but you will have to make one your self and put it on but be carefull if not put on right you can bend yor frame trust me tooke me two bikes too figure it out. there are some things you can do to them to stunt better change your gearing bigger sprocket in the back and find the tuneing needle and turn it up till it almost ingages the clutch better accleration .the blue bike the bars is a little to long so we cut it down alot the other blue bike my buddy made that bar and its not welded to the bike its bolted on so i can take it off if i want to but it sooooooo much fun. I hope i helped in some way if you have any more qustion just ask
Re: stunt parts?
unfortunetly i have the automatic version of the X1 so im looking for somethin to help me get the wheelies up and another problem is that im like 16 and im 5, 2 and only 85 lbs but i aprciate the help and from wat i see it looks like ur the pocket bike wheelie god!
Re: stunt parts?
speedFeak, I have a blata 2.5 which is a much smaller bike than yours. It also happens to be automatic. The way I leanred to wheelie mine was to go around 15-20 mph, then let off on the gas, pull up a bit and hitting the trottle. Before you try this, there are a few important things. 15-20 is the speed for my bike, probably not yours. To find the speed, it should be about the speed that the power of the bike really kicks in after a take-off. Another thing, if you happen to get the front wheel off the ground DO NOT let up on the gas. This will cause your front tire to slam down, breaking parts. (trust me, I know) When the wheel comes up, let off just a little but keep on the throttle some. The final thing is timing. Its hard to get timing right and if you an wheeli a bmx or mountain bike, you'll know about timing. good luck, hope this helped some.
nsschwenk
10-16-2012 06:34 PM
